Nikon Coolpix L840 Motherboard Replacement
Introduzione
Vai al passo 1This guide outlines the steps necessary to replace the circuit board of the camera. Many parts involved in this replacement are delicate, so it is important to be careful in their handling.
Cosa ti serve
Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
The strip may also be identified by its blue tip, which becomes more visible once pulled out.
Altre 3 persone hanno completato questa guida.
2 Commenti
I was trying to find how to replace the CCD lens sensor on the Nikon Coolpix L840
My camera display will work for a bit, but then goes off. Subsequent efforts to start it yield poor results. If I pick it up and try again in a few hours, I may have a short time to work before the screen goes dark. The batteries are new. I think this might be a case of blown capacitors on board, but I could use insight. The motherboard costs more than the camera now.
