Salta al contenuto principale
Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement
Alex Delony
Alex Delony e 3 altri collaboratori
Ultimo aggiornamento il July 3, 2020
15 minuti
Moderato
Introduzione
Vai al passo 1
This guide describes the steps necessary to remove and replace the LCD Monitor Connecting Arm of a Nikon Coolpix L830 camera.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement, Back Casing: passo 1, immagine 1 di 1
    • Use a Phillips #000 screwdriver to unscrew the two 3.0mm Phillips screws located on the side of the camera with the HDMI port.
    • The HDMI port side will be on the left if you are looking at the back of the camera with the LCD monitor.
    • One screw is located under the gray flap.
  2. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 2, immagine 1 di 1
    • Unscrew the five 3.0mm Phillips #000 screws that are located on the bottom side of the camera.
  3. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 3, immagine 1 di 1
    • Unscrew the 4.0mm Phillips #000 screw located underneath the grey flap on the side of the camera with the "DC IN 5.0 V" marker.
    • This will be on the right if you are looking at the back LCD monitor side.
    • Unscrew the exposed 3.0mm Phillips #000 screw on the same side.
  4. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 4, immagine 1 di 1
    • Press the flash button to open the flash component.
    • Remove the 3.0mm Phillips #000 screw located directly in-between the two arms.
  5. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 5, immagine 1 di 1
    • Open the LCD monitor to reveal two 2.0mm Phillips screws.
    • Remove the 2.0mm Phillips #000 screws.
  6. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 6, immagine 1 di 2 Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 6, immagine 2 di 2
    • Make sure to open the plastic grey flaps on either side of the camera before proceeding with this step.
    • Insert a plastic opening tool between the back and front surface components of the camera.
    • Wiggle the plastic opening tool backwards and forwards along the top edge until the back surface comes off.
    • Remove the back casing gently to not damage the LCD ribbon connector or inner camera components.
  7. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 7, immagine 1 di 2 Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 7, immagine 2 di 2
    • Gently pull the LCD ribbon connector up to allow the back casing to be completely removed.
  8. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement, LCD Connecting Arm: passo 8, immagine 1 di 1
    • On the inside of the back cover, remove the two 2.0mm Phillips screws surrounding the connecting cable.
  9. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: passo 9, immagine 1 di 1
    • Gently pull the ribbon connector in order to remove the complete LCD Monitor Connecting Arm.
Conclusione
Alex Delony
Membro da: 11/01/16
184 Reputazione
1 Guida realizzata
Baylor, Team 4-4, Williams Fall 2016 Membro di Baylor, Team 4-4, Williams Fall 2016
BU-WILLIAMS-F16S4G4
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 536
