Salta al contenuto principale
Nikon Coolpix L340 Buttons Replacement
Robert Estrella
Robert Estrella e 2 altri collaboratori
Ultimo aggiornamento il June 28, 2020
5 minuti
Facile
Introduzione
Vai al passo 1
This guide is meant to help the user replace the buttons on the back of the camera after they remove the back panel. This could be to fix a jammed button or simply replace the part as you wish. The only required tool for this process would be a 5mm Phillips Head number #000 screwdriver.
Cosa ti serve
Strumenti
  1. Nikon Coolpix L340 Buttons Replacement, Buttons: passo 1, immagine 1 di 1
    • Remove the 5 mm Phillips #000 screw located on the upper left side of the camera
    • Remove the 5 mm Phillips #000 screw located on the lower left side of the camera
  2. Nikon Coolpix L340 Buttons Replacement: passo 2, immagine 1 di 1
    • Remove the 5 mm Phillips #000 screw from the upper right side of the camera.
    • Remove the 5 mm Phillips #000 screw from the lower right side of the camera.
  3. Nikon Coolpix L340 Buttons Replacement: passo 3, immagine 1 di 1
    • Remove the 5 mm Phillips #000 screw from the bottom left of the camera.
    • Remove the 5 mm Phillips #000 screw from the left-center of the bottom of the camera.
    • Remove the 5 mm Phillips #000 screw from the center of the bottom of the camera.
  4. Nikon Coolpix L340 Buttons Replacement: passo 4, immagine 1 di 1
    • Remove back cover of the camera.
  5. Nikon Coolpix L340 Buttons Replacement: passo 5, immagine 1 di 1
    • Push buttons out of the back of the cover.
Conclusione
Robert Estrella
Membro da: 03/04/16
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,326
