Salta al contenuto principale
Nikon Coolpix L320 LCD Replacement
MollyHenderson
MollyHenderson e 2 altri collaboratori
Ultimo aggiornamento il May 18, 2023
Nessuna stima
Moderato
Necessarie Più Immagini
Introduzione Migliore
Dettagli Mancanti
Introduzione
Vai al passo 1
This guide will help walk you through how to replace the LCD screen in you Nikon Coolpix L320
Cosa ti serve
Strumenti
  1. Nikon Coolpix L320 LCD Replacement, Batteries: passo 1, immagine 1 di 2 Nikon Coolpix L320 LCD Replacement, Batteries: passo 1, immagine 2 di 2
    • Flip the camera over to reveal the card/battery door.
    • Slide the button to the unlocked position and the door should pop open.
  2. Nikon Coolpix L320 LCD Replacement: passo 2, immagine 1 di 2 Nikon Coolpix L320 LCD Replacement: passo 2, immagine 2 di 2
    • Take out the old batteries.
    • Look at the yellow sticker inside of the the battery compartment. You'll see the symbol for the direction the new battery should face when replaced.
    • The “+” means to put the raised end facing up. The “-“ means to put the flat end up.
  3. Nikon Coolpix L320 LCD Replacement, LCD: passo 3, immagine 1 di 3 Nikon Coolpix L320 LCD Replacement, LCD: passo 3, immagine 2 di 3 Nikon Coolpix L320 LCD Replacement, LCD: passo 3, immagine 3 di 3
    • Use a JIS screwdriver to remove seven screws from the frame of camera.
  4. Nikon Coolpix L320 LCD Replacement: passo 4, immagine 1 di 1
    • Use an opening tool or spudger to separate the front and back of the camera.
  5. Nikon Coolpix L320 LCD Replacement: passo 5, immagine 1 di 1
    • Use a JIS screwdriver to remove the screws connecting the LCD to the motherboard.
  6. Nikon Coolpix L320 LCD Replacement: passo 6, immagine 1 di 1
    • Gently flip the LCD over to reveal a ribbon cable connected to the motherboard.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector. Then, you can safely pull the cable out.
    • Remove the LCD screen from the camera.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 281
