Salta al contenuto principale
Nikon Coolpix L32 Memory Card Replacement
Weston Phillips
Weston Phillips e 3 altri collaboratori
Ultimo aggiornamento il June 26, 2020
15 - 30 secondi
Molto facile
Introduzione
Vai al passo 1
The guide will show how to properly replace a memory card from the Nikon Coolpix L32 camera.
  1. Nikon Coolpix L32 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 1
    • Slide the lock button on the battery compartment away from you while sliding the battery compartment door to the right to open the battery compartment door.
  2. Nikon Coolpix L32 Memory Card Replacement: passo 2, immagine 1 di 1
    • Push in the memory card until you hear a “click” noise, remove the old one and install the new one
    • When the new memory card is being installed make sure to hear a "click" noise once again
Conclusione
USF Tampa, Team 2-4, Blackwell Fall 2016 Membro di USF Tampa, Team 2-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G4
4 Membri
10 Guide realizzate
Un commento
Very informative
Simon Munoz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 703
