Salta al contenuto principale
Nikon Coolpix L26 Camera LCD Screen Replacement
Sadie
Sadie e 3 altri collaboratori
Ultimo aggiornamento il June 25, 2020
15 minuti
Moderato
Introduzione
Vai al passo 1
This repair guide follows the back cover guide and requires the use of the spudger tool and Phillips screwdriver.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
Mostra di più…
  1. Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: passo 1, immagine 1 di 3 Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: passo 1, immagine 2 di 3 Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
  2. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 2, immagine 1 di 1
    • Using the Phillips #000 screwdriver, unscrew the two 2mm screws next to the battery compartment on the right side of the camera.
  3. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 3, immagine 1 di 1
    • Unscrew the two 2mm screws on the opposite side.
  4. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 4, immagine 1 di 1
    • Flip over the rubber AV cover at the bottom of the camera. Unscrew the last two 2mm screws on the bottom of the camera.
  5. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 5, immagine 1 di 3 Nikon Coolpix L26 Camera LCD Screen Replacement: passo 5, immagine 2 di 3 Nikon Coolpix L26 Camera LCD Screen Replacement: passo 5, immagine 3 di 3
    • Using your hands, open the camera slightly by using the indentation above the camera compartment.
  6. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 6, immagine 1 di 2 Nikon Coolpix L26 Camera LCD Screen Replacement: passo 6, immagine 2 di 2
    • Wedge the flat end of the spudger in between the front and back cover. Carefully push the spudger downward, which will lift the back cover off the camera.
  7. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 7, immagine 1 di 1
    • Gently pull the cover off the camera.
  8. Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: passo 8, immagine 1 di 3 Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: passo 8, immagine 2 di 3 Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: passo 8, immagine 3 di 3
    • Carefully flip over the LCD screen onto its front. Pull the top of the LCD screen toward you keeping the bottom of it inside the camera.
    • Do not pull on the LCD screen; there is a ribbon of circuitry that is connected to the motherboard.
  9. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 9, immagine 1 di 1
    • Gently hold the LCD screen down, so the ribbon lays flat against the back of the camera.
  10. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 10, immagine 1 di 1
    • Gently wedge the spudger underneath the white latch and lift the latch open.
  11. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 11, immagine 1 di 2 Nikon Coolpix L26 Camera LCD Screen Replacement: passo 11, immagine 2 di 2
    • Use the flat side of the spudger to flip the white switch on the motherboard. You should hear a light click.
  12. Nikon Coolpix L26 Camera LCD Screen Replacement: passo 12, immagine 1 di 1
    • Gently pull the ribbon out of the switch.
Conclusione
Altre 3 persone hanno completato questa guida.
Sadie
Membro da: 02/16/15
427 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,370
