Salta al contenuto principale
Nikon Coolpix L16 LCD screen replacement
oldturkey03
oldturkey03 e 2 altri collaboratori
Ultimo aggiornamento il June 23, 2020
15 - 30 minuti
Moderato
Guida In Evidenza
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Use this guide to replace the LCD.
Cosa ti serve
Strumenti
  1. Nikon Coolpix L16 LCD screen replacement, LCD: passo 1, immagine 1 di 3 Nikon Coolpix L16 LCD screen replacement, LCD: passo 1, immagine 2 di 3 Nikon Coolpix L16 LCD screen replacement, LCD: passo 1, immagine 3 di 3
    • Clearly visible damage to the LCD. It did not even light up.
    • Remove the screw from the right side.
    • Remove the visible screw from the left side.
  2. Nikon Coolpix L16 LCD screen replacement: passo 2, immagine 1 di 3 Nikon Coolpix L16 LCD screen replacement: passo 2, immagine 2 di 3 Nikon Coolpix L16 LCD screen replacement: passo 2, immagine 3 di 3
    • Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers...
    • Remove the three screws from the bottom.
    • Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
  3. Nikon Coolpix L16 LCD screen replacement: passo 3, immagine 1 di 3 Nikon Coolpix L16 LCD screen replacement: passo 3, immagine 2 di 3 Nikon Coolpix L16 LCD screen replacement: passo 3, immagine 3 di 3
    • After the splitting of the case, the LCD is imediately visible.
    • Lift the LCD out of the frame by using your fingernail or an opening tool. Do not remove it yet, it is still connected.
    • Flip the black clasp up by using fingernails or the opening tool. No big force is required. Remove the old LCD.
  4. Nikon Coolpix L16 LCD screen replacement: passo 4, immagine 1 di 2 Nikon Coolpix L16 LCD screen replacement: passo 4, immagine 2 di 2
    • Here is the new screen, note the blue tab. This is the screen protector, remove it after installation.
    • Reassemble in reverse order. Hopefully your results will be the same as for me.
Conclusione
oldturkey03
Membro da: 09/29/10
813.073 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
45 Membri
702 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 55
Tutti i Tempi: 3,127
