Salta al contenuto principale
Nikon Coolpix AW130 Battery Door Replacement
Lauren Stepp
Lauren Stepp e un altro collaboratore
Ultimo aggiornamento il June 17, 2020
10 minuti
Facile
Introduzione
Vai al passo 1
Safely replacing the battery door is a necessary step in protecting the internal components of the camera. Thoroughly completing this process also protects the waterproof integrity of the piece.
Cosa ti serve
Strumenti
  1. Nikon Coolpix AW130 Battery Door Replacement, Battery: passo 1, immagine 1 di 2 Nikon Coolpix AW130 Battery Door Replacement, Battery: passo 1, immagine 2 di 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Door Replacement: passo 2, immagine 1 di 2 Nikon Coolpix AW130 Battery Door Replacement: passo 2, immagine 2 di 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Door Replacement: passo 3, immagine 1 di 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
    This yellow tab spring broken, how I can repair
    Surendra kumar - Replica
    From where I can get this yellow tab, and how I can replace
  4. Nikon Coolpix AW130 Battery Door Replacement: passo 4, immagine 1 di 2 Nikon Coolpix AW130 Battery Door Replacement: passo 4, immagine 2 di 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: passo 5, immagine 1 di 2 Nikon Coolpix AW130 Battery Door Replacement, Battery Door: passo 5, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
  6. Nikon Coolpix AW130 Battery Door Replacement: passo 6, immagine 1 di 1
    • Using the metal spudger, carefully pry on the plastic plate.
    • The plastic plate should begin to loosen. Completely remove it from the camera body.
  7. Nikon Coolpix AW130 Battery Door Replacement: passo 7, immagine 1 di 2 Nikon Coolpix AW130 Battery Door Replacement: passo 7, immagine 2 di 2
    • Open the battery door. Near the hinge, a pair of screws should now be exposed.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
  8. Nikon Coolpix AW130 Battery Door Replacement: passo 8, immagine 1 di 1
    • Pull the battery door away from the camera body.
Conclusione
6 Commenti
Where can I purchase the battery cover?
Thanh Tran - Replica
Where can I buy the AW130 battery door?
Jose - Replica
I’m trying to replace the battery door. I removed the 2 bottom screws and loosened the plate as in Steps 5 and 6. How do I remove the plate without breaking it?
Jose - Replica
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Marianne Chaffin Strickland - Replica
Need web site to order battery door?
Connie Mossor - Replica
The spring that holds the yellow tab over the battery is apparently broken/loose on my camera, and was wondering if there is a solution without replacing the camera or using an external battery charger?
Brady Mattsson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,356
