Nikon Coolpix 4600 Lens and Flash Assembly Replacement
Introduzione
Vai al passo 1This installation guide will help you remove and replace the flash assembly for the Nikon Coolpix 4600 camera. The lens assembly is very intricate and complicated, disassembly of the actual lens assembly should only be attempted by a professional. This guide will demonstrate how to remove and replace the assembly as a whole unit.
Cosa ti serve
Find the six screws on the exterior of the camera: two 3.3 mm screws on the bottom and two 5.25 mm screws on both the left and right sides.
Using a Phillips 00 screwdriver, remove all of the six screws.
Examine the connection between the ribbon cable and the motherboard closely. Identify the two grey tabs on each side of the connecting bracket.
Slide the grey tabs toward the bottom of the camera to release the ribbon cable. Gently disconnect the ribbon cable from the motherboard.
Once the ribbon cable is disconnected, you can now carefully separate the back case from the front case.
Locate and remove the four 4.25 mm screws on the motherboard using a Phillips 00 screw driver.
The flash and lens assembly should now be separate from the motherboard.
Locate the capacitor. It is the component that looks similar in size and shape to a AAA battery.
With the lens upright and facing you, gently lift the capacitor up and to the left to remove main flash assembly.
