Salta al contenuto principale
Nikon COOLPIX P600 Battery Replacement
Geronimo Gutierrez IV
Geronimo Gutierrez IV e 3 altri collaboratori
Ultimo aggiornamento il June 17, 2024
30 secondi
Molto facile
Introduzione
Vai al passo 1
In this guide you will learn how to replace the Nikon COOLPIX P600 battery, in as little as three easy steps. The steps will include where the battery compartment is located, what the switch to the battery cover looks like, and how to remove the battery.
Additional Information
Nikon COOLPIX P600 Technical Specifications
Nikon COOLPIX P600 Service & Support
  1. Nikon COOLPIX P600 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the camera upside down so that the lens is facing away from you.
  2. Nikon COOLPIX P600 Battery Replacement: passo 2, immagine 1 di 2 Nikon COOLPIX P600 Battery Replacement: passo 2, immagine 2 di 2
    • Slide the switch on the battery cover towards the center of the camera.
  3. Nikon COOLPIX P600 Battery Replacement: passo 3, immagine 1 di 2 Nikon COOLPIX P600 Battery Replacement: passo 3, immagine 2 di 2
    • Once the battery cover is open, push the solid yellow tab in the direction of the arrow. This will then eject the battery out of the camera.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure the battery is pushed back into the battery compartment enough to have the yellow latch seen in step three click back over the top of the battery before attempting to close the battery cover.
Documenti Allegati
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,352
