Salta al contenuto principale
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
Nexus 10 Display Replacement
Benjamin Troller
Benjamin Troller e 5 altri collaboratori
Ultimo aggiornamento il 2 feb 2018
Nessuna stima
Moderato
Introduzione Migliore
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Nexus 10 Display Replacement, Battery: passo 1, immagine 1 di 3 Nexus 10 Display Replacement, Battery: passo 1, immagine 2 di 3 Nexus 10 Display Replacement, Battery: passo 1, immagine 3 di 3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Display Replacement: passo 2, immagine 1 di 1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Display Replacement: passo 3, immagine 1 di 3 Nexus 10 Display Replacement: passo 3, immagine 2 di 3 Nexus 10 Display Replacement: passo 3, immagine 3 di 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
    Be carefull with the power button cable. Don’t insert the plastic tool in this zone
    Jesus Garcia - Replica
    Some instruction guides also suggest optional use of a suction cup with which to tug on the glass while separating the plastic backing. I found this helpful. Also, if you have a spudger of more rigid plastic, use that one here. My blue spudgers got chewed up pretty badly during this process.
    Jim - Replica
    I found that the top right (looking at the screen) doesn’t have any corner clips, just a metal antenna (?), so it is easiest to get this corner popped first and then work your way around. The bottom corners have clips which are tough to undo.
    Jeremy R - Replica
  4. Nexus 10 Display Replacement: passo 4, immagine 1 di 3 Nexus 10 Display Replacement: passo 4, immagine 2 di 3 Nexus 10 Display Replacement: passo 4, immagine 3 di 3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
    The left two connectors flip up from the cable side. The right connector flips up from opposite the cable.
    Glenn Davis - Replica
    Note that you don’t just pull the ribbons out. There is a clamp on each connector that needs to be prised opened, releasing the ribbon. This was helpful: https://youtu.be/yru4k62qdEU?t=302
    Royston Shufflebotham - Replica
    You sir, are a true humanitarian!!!
    Harold Gue - Replica
  5. Nexus 10 Display Replacement: passo 5, immagine 1 di 1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Display Replacement: passo 6, immagine 1 di 2 Nexus 10 Display Replacement: passo 6, immagine 2 di 2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
    When reassembling reconnect the data ribbon cables first, then connect the battery connection last so that you’re not plugging in data lines while powered. Ideally you’d disconnect the battery first but that’s a bit hard with the design so you just have to try to ensure it’s switched off first.
    Andrew Whalan - Replica
    Excellent with video
    Jim Scott - Replica
  7. Nexus 10 Display Replacement, Headphone Jack: passo 7, immagine 1 di 1
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Display Replacement: passo 8, immagine 1 di 3 Nexus 10 Display Replacement: passo 8, immagine 2 di 3 Nexus 10 Display Replacement: passo 8, immagine 3 di 3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Display Replacement: passo 9, immagine 1 di 3 Nexus 10 Display Replacement: passo 9, immagine 2 di 3 Nexus 10 Display Replacement: passo 9, immagine 3 di 3
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Display Replacement: passo 10, immagine 1 di 2 Nexus 10 Display Replacement: passo 10, immagine 2 di 2
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Display Replacement: passo 11, immagine 1 di 1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Display Replacement: passo 12, immagine 1 di 2 Nexus 10 Display Replacement: passo 12, immagine 2 di 2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
    Expect some resistance when prying up on the vibration motor. There was some aggressive double sided tape under it and it was stuck pretty firmly.
    Jim - Replica
  13. Nexus 10 Display Replacement: passo 13, immagine 1 di 2 Nexus 10 Display Replacement: passo 13, immagine 2 di 2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Display Replacement: passo 14, immagine 1 di 2 Nexus 10 Display Replacement: passo 14, immagine 2 di 2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
  15. Nexus 10 Display Replacement, Display: passo 15, immagine 1 di 2 Nexus 10 Display Replacement, Display: passo 15, immagine 2 di 2
    • Detach LCD connector ribbon by pressing upward on connector latch using a plastic opening tool.
  16. Nexus 10 Display Replacement: passo 16, immagine 1 di 2 Nexus 10 Display Replacement: passo 16, immagine 2 di 2
    • Unscrew the two 2mm Phillips #00 screws holding the ribbon in place.
    • Remove the board by tilting it forward and pulling outward.
  17. Nexus 10 Display Replacement: passo 17, immagine 1 di 1
    • Remove second speaker by gently tilting and pulling upward.
  18. Nexus 10 Display Replacement: passo 18, immagine 1 di 3 Nexus 10 Display Replacement: passo 18, immagine 2 di 3 Nexus 10 Display Replacement: passo 18, immagine 3 di 3
    • Unscrew the two 2mm screws securing the micro HDMI connector with a #PH00 screwdriver.
    • Remove the connector by liberally applying upward pressure.
  19. Nexus 10 Display Replacement: passo 19, immagine 1 di 3 Nexus 10 Display Replacement: passo 19, immagine 2 di 3 Nexus 10 Display Replacement: passo 19, immagine 3 di 3
    • Unscrew the 2mm Phillips #00 screw that holds the flash enclosure.
    • Remove the flash assembly with a plastic opening tool by lifting the assembly upward.
    Where can I buy Nexus 10 front glass, pls recommend.
    sandesh30715 - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 34-18, Maness Spring 2016 Membro di Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Membri
5 Guide realizzate
4Commenti sulla guida
I’m waiting for the instructions regarding how to remove the old screen and insert the new - it seems to be missing
John Walker - Replica
It seems you just have to buy a replacement for that whole front housing, including the screen assembly
Oliver Nichol -
Still waiting to see how the screen is remove
Frank - Replica
he cambiado la bateria y he partido el presor negro del conector de LCD y no me me funciona, se puede comprar esa pieza negra?
Diego Mera - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 8,416
