Salta al contenuto principale
Nest Hello Button Replacement
Daniel Moore
Daniel Moore e 3 altri collaboratori
Ultimo aggiornamento il 20 gen 2025
25 - 30 minuti
Moderato
Necessarie Più Immagini
Passi mancanti
Introduzione
Vai al passo 1
If the doorbell button on your Nest Hello is cracked or leaking, this guide will help you access and replace it. During disassembly, it is easy to damage the waterproofing O-Ring, so plan on replacing that as well. This does involve removing all of the internals from the device using the iFixit opening picks, Phillips #000 screwdriver, and tweezers. Be sure to take your time and keep track of screws and other parts.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nest Hello Button Replacement, Casing and Faceplate: passo 1, immagine 1 di 1
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
    I had to use a metal spudger tool to start and then used guitar picks.
    Joel Lundi - Replica
    Be afraid to pull hard. The faceplate will break in two.
    B Bremer - Replica
    I did the JerryRigEverything method and slipped a razor under the faceplate to separate it carefully from the body. Worked perfectly and nothing was damaged
    There I Fixed It - Replica
    Be careful with the wiring and the heater element. I must have shorted something together when it put it back together and now it will no longer power up. It is probably best to cut the wires to the heater and deal with the consequences in the cold temperatures.
    Joe I. Fabritz - Replica
    The secret I think is slicing through the adhesive. I shoved multiple picks in and worked my way around. You want to cut the adhesive. Prying is likely to break the faceplate. The big hint is the next picture in the step, seeing where the adhesive is.
    Arnold de Leon - Replica
  2. Nest Hello Button Replacement: passo 2, immagine 1 di 2 Nest Hello Button Replacement: passo 2, immagine 2 di 2
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
    There is a small circle sticker over each screw, about the size of the red circles in the image above. It wasn't clear from the directions what the "cover stickers" were. A small exacto knife was helpful to pry up the edge of each sticker.
    Tim Scott - Replica
  3. Nest Hello Button Replacement: passo 3, immagine 1 di 3 Nest Hello Button Replacement: passo 3, immagine 2 di 3 Nest Hello Button Replacement: passo 3, immagine 3 di 3
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
    Where can you get a replacement faceplate from?
    nick - Replica
    I ended up doing the headlight lens restoration method - I scraped away any plastic that was flaking off and then I used progressively finer sandpaper (start with 400-600 grit and go up from there). I finished it with rubbing compound and polish. Looks decent.
    Also - be careful not to cut or displace the rubber gasket that runs around the outside of the main body that has the circuitry - you'll risk losing the waterproofing
    What is the replacement battery type please?
    Dave Pawson - Replica
    BUSFUIVA Replacement Battery for Nest 1ICP7/17/26, Hello, NC5100US, C1241290, Vido Doorbell Wired. 3.7V 280MAH https://a.co/d/38BD8qY
    Brandon H -
    The top end has some kind of mild adhesive (the blue stuff). The bottom end came out more easily for me, and then I ended up bending my board slightly by trying to pry out the top end. May be better to start on the top end if you can get something under the edge of the board to get leverage.
    somebody - Replica
    The black ribbon cable was instantly sheared in half the moment I got the two halves apart, which took more force than I was hoping to need. Turns out the ribbon cable is attached to a sharp metal piece and it will easily tear through it. No longer worth it to replace the battery for me, sadly.
    Ryan Littlefield - Replica
    What a stupid design by Nest. If they know that battery will fail they should at least make it user accessible when removed from mount. Replaced mine. It’s a pain getting to the battery and it’s easy to crack the faceplate when prying it off. Also the plastic tools included with kit will fail before you’re into the device.
    If you can manage to get to the battery without destroying the Nest Doorbell it’s worth it to get a few more years of use.
    C Whitcher - Replica
    Some more clarity about where the ribbon cable is located would be helpful. It is unclear from the photos which side it is on and I was very apprehensive about where to separate the bodies while avoiding severing it.
    Jensie - Replica
    The pick was inadequate to separate the two parts. It actually broke. Had to use a flat head screw driver.
    Jensie - Replica
  4. Nest Hello Button Replacement, Motherboard: passo 4, immagine 1 di 1
    • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
  5. Nest Hello Button Replacement: passo 5, immagine 1 di 2 Nest Hello Button Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Grip the connector with the tweezers as shown and pull it away from the casing.
  6. Nest Hello Button Replacement: passo 6, immagine 1 di 1
    • Remove the six smaller screws shown with the Phillips #000 screwdriver.
    • Remove the three larger screws shown with the Phillips #000 screwdriver.
    I didn't see a reason to proceed with step 7 - 10 as the battery was replaceable at this point. I just used my tweezers to pull the battery connector out and insert the new one. I probably could've stopped earlier and skipped removing the USB connector.
    Jay Chin - Replica
  7. Nest Hello Button Replacement: passo 7, immagine 1 di 2 Nest Hello Button Replacement: passo 7, immagine 2 di 2
    • Holding the device as shown push the circuit board away from you and up to free it from the clips.
  8. Nest Hello Button Replacement: passo 8, immagine 1 di 2 Nest Hello Button Replacement: passo 8, immagine 2 di 2
    • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
  9. Nest Hello Button Replacement: passo 9, immagine 1 di 1
    • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
    • Work your way around the device, prying the circuit board away from the housing.
    • Make sure to feed the wires when taking off the circuit board.
    • Once the circuitboard is free from the plastic housing, the button can be removed by pushing on it from the front side.
    Good explanation but need photos for removing button and purchasing parts
Conclusione
Preparati per le riparazioni future
Acquista tutti
2Commenti sulla guida
Where do you get the parts. Google is no help. I’m trying to get the black faceplate from your first step. I can’t find it.
Ryan Gauder - Replica
Where do I buy a button?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,352
