Salta al contenuto principale
Nespresso Pixie Internal Diffuser Replacement
Drew
Drew e 5 altri collaboratori
Ultimo aggiornamento il April 9, 2025
45 minuti - 1 ora
Difficile
Introduzione
Vai al passo 1
The chosen product here is the Nespresso Pixie. This repair guide will give you all of the necessary tools in order to replace the internal diffuser plate. The guide will take approximately 45 minutes to an hour depending on past experience. At this end of this guide, you will be able to completely take apart this machine in order to cleanse or replace the internal diffuser plate. The most challenging issue you have will be pulling with enough force to pull it apart without breaking it.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nespresso Pixie Internal Diffuser Replacement, Internal Diffuser: passo 1, immagine 1 di 1
    • Unplug the machine from any outlets.
    • Remove the water tank by pressing the top button and pulling outwards.
    • Make sure there is no fluid left in any part of the machine.
  2. Nespresso Pixie Internal Diffuser Replacement: passo 2, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 2, immagine 2 di 2
    • Use a Torx T5 screwdriver to detach the lever of the machine on both sides.
  3. Nespresso Pixie Internal Diffuser Replacement: passo 3, immagine 1 di 1
    • Remove the drip tray using your hand.
  4. Nespresso Pixie Internal Diffuser Replacement: passo 4, immagine 1 di 1
    • Use your hand to remove the black drip tray grill behind the drip tray.
  5. Nespresso Pixie Internal Diffuser Replacement: passo 5, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 5, immagine 2 di 2
    • Use a Torx T4 screwdriver to unscrew each screw on the faceplates.
    • Remove the faceplate using a metal spudger.
    • Be sure to start in both corners to separate the pieces.
  6. Nespresso Pixie Internal Diffuser Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Locate the two springs in each top right corner and use a set of tweezers to remove them.
    • Be sure to set the machine in an enclosed container when this is done so as to not to lose the springs.
  7. Nespresso Pixie Internal Diffuser Replacement: passo 7, immagine 1 di 1
    • Take off the white plastic bits using a metal spudger.
    Wrong way to remove it
    biorn - Replica
  8. Nespresso Pixie Internal Diffuser Replacement: passo 8, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 8, immagine 2 di 2
    • Remove the clear plastic bits using a metal spudger.
    • Be sure to pull it out using the hole in which it is indented.
    Wrong way to remove it.
    There is a clips on the other side. Remove connector first
    biorn - Replica
  9. Nespresso Pixie Internal Diffuser Replacement: passo 9, immagine 1 di 1
    • Use your hands to remove the cables that give power to the machine.
    Need a tool never pull a connector from wire 😤
    biorn - Replica
  10. Nespresso Pixie Internal Diffuser Replacement: passo 10, immagine 1 di 1
    • Use your hands to remove the water spout.
    Can’t be removed by hand
    biorn - Replica
  11. Nespresso Pixie Internal Diffuser Replacement: passo 11, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 11, immagine 2 di 2
    • Seperate both halves of the machine using both a spudger and your hands.
    • Once you have unclipped the side at the top, middle of the side and base. You can push with a screw driver through the hole on the reverse side to help remove the plastic side.
    • Be sure to take your time and start in the middle. Note that it is incredibly well secured.
  12. Nespresso Pixie Internal Diffuser Replacement: passo 12, immagine 1 di 1
    • Use your hands to pull out the first lever housing in the spot shown in the picture.
  13. Nespresso Pixie Internal Diffuser Replacement: passo 13, immagine 1 di 1
    • Pull the brewing mechanism apart from the remaining plastic barrier.
    • Once it is separated, pull off the other lever housing in the same way as was described in the previous step.
  14. Nespresso Pixie Internal Diffuser Replacement: passo 14, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 14, immagine 2 di 2
    • Use a spudger to unclip the clips holding the black case in place.
    • Pull the brewing chamber outwards from the machine and then pull it downwards to detach it.
  15. Nespresso Pixie Internal Diffuser Replacement: passo 15, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 15, immagine 2 di 2
    • Pry off the clips holding the inner white chamber in place in the machine.
  16. Nespresso Pixie Internal Diffuser Replacement: passo 16, immagine 1 di 1
    • Use a spudger to take off your diffuser plate.
    • Insert your new diffuser plate.
Conclusione
Drew
Membro da: 11/05/23
253 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 Membro di UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G2
4 Membri
13 Guide realizzate
1Commento della guida
I’m sorry but this tutorial should be removed. You’ll just going to broke parts by following that.
biorn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 163
Tutti i Tempi: 2,251
