Salta al contenuto principale
Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement
Elizabeth Coffey
Elizabeth Coffey e 5 altri collaboratori
Ultimo aggiornamento il December 28, 2016
35 - 45 minuti
Moderato
Fallo a Fettine
Introduzione
Vai al passo 1
A damaged hammer rod may make it difficult, or entirely prevent the slide from operating. This can make loading the rifle difficult. This guide shows you how to access and replace the silver hammer rod next to the barrel of the Nerf gun.
Cosa ti serve
Ricambi
Strumenti
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Notes Before Starting: passo 1, immagine 1 di 1
    • There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
    • Be sure that the rifle is discharged and unloaded before starting disassembly.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: passo 2, immagine 1 di 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: passo 2, immagine 2 di 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: passo 2, immagine 3 di 3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: passo 3, immagine 1 di 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: passo 3, immagine 2 di 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: passo 3, immagine 3 di 3
    • With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 4, immagine 1 di 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 4, immagine 2 di 2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 5, immagine 1 di 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 5, immagine 2 di 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 5, immagine 3 di 3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Spring Removal: passo 6, immagine 1 di 1
    • You should now be able to pull the main firing spring from the rear of the rifle.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Hammer Rod: passo 7, immagine 1 di 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Hammer Rod: passo 7, immagine 2 di 2
    • Remove the two 5 mm phillips screws holding the muzzle in place.
  8. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 8, immagine 1 di 1
    • Remove the barrel and muzzle assembly from the gun body.
  9. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 9, immagine 1 di 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 9, immagine 2 di 2
    • Remove the 5mm phillips screw holding in the chamber lock mechanism.
  10. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 10, immagine 1 di 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 10, immagine 2 di 2
    • Pull the front chamber lock spring up and out of its seat.
    • Pull the front chamber lock mechanism down and out of the rifle barrel.
    • Note there are two pieces to this mechanism.
  11. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 11, immagine 1 di 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 11, immagine 2 di 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 11, immagine 3 di 3
    • Holding the rear chamber slide lock down, slide the chamber to the rear of the rifle.
    • Remove the rear section of the barrel.
  12. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 12, immagine 1 di 1
    • With the plunger in the air cylinder, pull the plunger lock out of the rifle body.
  13. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 13, immagine 1 di 1
    • Pull the air cylinder and plunger assembly rearwards and out of the rifle.
  14. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 14, immagine 1 di 1
    • While holding the slide lock mechanism down, pull the bullet chamber assembly up and out of the rifle.
    • Part of the magazine lock mechanism should come along with it.
  15. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 15, immagine 1 di 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 15, immagine 2 di 2
    • With the hammer rod side of the bullet chamber facing you, unscrew the 5 mm phillips screw holding the hammer rod in place.
  16. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: passo 16, immagine 1 di 1
    • Remove the hammer rod.
Conclusione
Cal Poly, Team 10-35, Maness Winter 2014 Membro di Cal Poly, Team 10-35, Maness Winter 2014
CPSU-MANESS-W14S10G35
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 18
Tutti i Tempi: 7,630
