Salta al contenuto principale
Nerf N-Strike Deploy CS-6 Battery Replacement
Brenda
Brenda e 3 altri collaboratori
Ultimo aggiornamento il December 20, 2016
3 minuti
Facile
Introduzione
Vai al passo 1
The device is accompanied with a flashlight in order to be used effectively in the dark. The light will only turn on if using the proper batteries. This guide will show you how to remove the batteries from their compartment and properly place in three Triple A batteries. Following these steps will allow the flashlight to function properly.
Cosa ti serve
Strumenti
  1. Nerf N-Strike Deploy CS-6 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the screwdriver on the screw and begin taking it out.
    • Turn the screw counter-clockwise.
  2. Nerf N-Strike Deploy CS-6 Battery Replacement: passo 2, immagine 1 di 1
    • The lid that covers the batteries should then rise up slightly, allowing it to be pulled off.
  3. Nerf N-Strike Deploy CS-6 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the batteries.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,256
