Salta al contenuto principale
Nabi 2  Screen Replacement
Michelle
Michelle e 3 altri collaboratori
Ultimo aggiornamento il 6 mar 2019
10 - 15 minuti
Facile
Foto Azione
Introduzione
Vai al passo 1
Before beginning this guide we recommend following our Nabi 2 back cover removal guide.
This guide will walk you through the steps of replacing a cracked or otherwise non functioning screen on a Nabi 2. As the screen is glued to the front assembly, we recommend replacing the entire display assembly.
Be sure to use caution when releasing the clips that secure the display ribbon cables. Use a plastic spudger and push directly out, do not pry up on the clips, they will break.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 1 di 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 2 di 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 3 di 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2  Screen Replacement: passo 2, immagine 1 di 2 Nabi 2  Screen Replacement: passo 2, immagine 2 di 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2  Screen Replacement: passo 3, immagine 1 di 3 Nabi 2  Screen Replacement: passo 3, immagine 2 di 3 Nabi 2  Screen Replacement: passo 3, immagine 3 di 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2  Screen Replacement, Screen: passo 4, immagine 1 di 3 Nabi 2  Screen Replacement, Screen: passo 4, immagine 2 di 3 Nabi 2  Screen Replacement, Screen: passo 4, immagine 3 di 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2  Screen Replacement: passo 5, immagine 1 di 3 Nabi 2  Screen Replacement: passo 5, immagine 2 di 3 Nabi 2  Screen Replacement: passo 5, immagine 3 di 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
    que aser cuando no le pasa carga a la bateria
    yordenis sanchez - Replica
    Where can I go to get a new screen
    Reis Brooks - Replica
Conclusione
Altre 7 persone hanno completato questa guida.
Michelle
Membro da: 02/09/16
875 Reputazione
4 Guide realizzate
USF Tampa, Team 4-3, Lacy Spring 2016 Membro di USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Membri
14 Guide realizzate
4Commenti sulla guida
Simple steps but very practical
myjamro - Replica
Is the LCD glued to the front glass/digitizer?
Brent Huff - Replica
It Worked Thank U So Much!!!
Sharon Thrash - Replica
a piece that holds the screen ribbon cable in broke off my nabis motherboard while taking the screen off. I eventually did get the screen back on.
NabiGuy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 7,996
