Salta al contenuto principale
Motorola Moto G7 Power Daughterboard Replacement
Cosa ti serve
  1. Motorola Moto G7 Power Daughterboard Replacement, Weaken the adhesive: passo 1, immagine 1 di 1
    • Apply a heated iOpener or a heat gun to the bottom edge of the screen for approximately two minutes to help soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G7 Power Daughterboard Replacement, Loosen the rear cover: passo 2, immagine 1 di 3 Motorola Moto G7 Power Daughterboard Replacement, Loosen the rear cover: passo 2, immagine 2 di 3 Motorola Moto G7 Power Daughterboard Replacement, Loosen the rear cover: passo 2, immagine 3 di 3
    • Apply a suction cup to the rear cover, as close to the heated edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert an opening pick into the gap you created under the rear cover.
  3. Motorola Moto G7 Power Daughterboard Replacement: passo 3, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement: passo 3, immagine 2 di 2
    • Slide the pick along the bottom of the gap to slice through the adhesive securing the rear cover to the midframe.
    • After being cut, the adhesive will sometimes stick back together as it cools. To prevent this, you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
  4. Motorola Moto G7 Power Daughterboard Replacement: passo 4, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement: passo 4, immagine 2 di 2
    • Slide the pick along the gap on the same side of the phone as the SIM card tray to slice through the adhesive securing the rear cover to the midframe.
  5. Motorola Moto G7 Power Daughterboard Replacement: passo 5, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement: passo 5, immagine 2 di 2
    • Slide the pick along the gap at the top of the phone to slice through the adhesive securing the rear cover to the midframe.
  6. Motorola Moto G7 Power Daughterboard Replacement: passo 6, immagine 1 di 3 Motorola Moto G7 Power Daughterboard Replacement: passo 6, immagine 2 di 3 Motorola Moto G7 Power Daughterboard Replacement: passo 6, immagine 3 di 3
    • Slightly lift up the rear cover starting from the right side.
    • This will prevent damage to the fingerprint sensor connector under the left side of the rear cover.
    • If lifting the rear cover is difficult, slice through any remaining adhesive with an opening pick. Reapplying the iOpener can also help weaken the adhesive.
    • Use a finger to press down on the fingerprint sensor until it separates from the rear cover.
  7. Motorola Moto G7 Power Daughterboard Replacement, Remove the rear cover: passo 7, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement, Remove the rear cover: passo 7, immagine 2 di 2
    • Remove the rear cover, taking care not to damage the fingerprint sensor.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
  8. Motorola Moto G7 Power Daughterboard Replacement, Remove the fingerprint sensor: passo 8, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement, Remove the fingerprint sensor: passo 8, immagine 2 di 2
    • Insert the pointed end of a spudger into the divot at the top of the fingerprint sensor connector cover.
    • Gently pry the cover open.
    • Remove the cover.
  9. Motorola Moto G7 Power Daughterboard Replacement: passo 9, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement: passo 9, immagine 2 di 2
    • Use the pointed end of a spudger to pry up on the fingerprint sensor connector to disconnect it.
  10. Motorola Moto G7 Power Daughterboard Replacement, Remove the motherboard cover: passo 10, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the ten screws securing the motherboard cover to the midframe:
    • Nine 3.5 mm screws
    • One 3.0 mm screw
  11. Motorola Moto G7 Power Daughterboard Replacement: passo 11, immagine 1 di 3 Motorola Moto G7 Power Daughterboard Replacement: passo 11, immagine 2 di 3 Motorola Moto G7 Power Daughterboard Replacement: passo 11, immagine 3 di 3
    • Insert the flat end of a spudger under the motherboard cover.
    • Pry the motherboard cover upwards to lift it from the motherboard.
    • Remove the motherboard cover.
  12. Motorola Moto G7 Power Daughterboard Replacement, Disconnect the battery: passo 12, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement, Disconnect the battery: passo 12, immagine 2 di 2
    • Use the flat end of a spudger to pry up on the battery connector to disconnect it.
  13. Motorola Moto G7 Power Daughterboard Replacement, Remove the daughterboard cover: passo 13, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the four 2.5 mm screws securing the daughterboard cover to the midframe.
  14. Motorola Moto G7 Power Daughterboard Replacement: passo 14, immagine 1 di 3 Motorola Moto G7 Power Daughterboard Replacement: passo 14, immagine 2 di 3 Motorola Moto G7 Power Daughterboard Replacement: passo 14, immagine 3 di 3
    • Insert the flat end of a spudger under the daughterboard cover and pry upwards.
    • Remove the daughterboard cover.
  15. Motorola Moto G7 Power Daughterboard Replacement, Disconnect the antenna cables: passo 15, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement, Disconnect the antenna cables: passo 15, immagine 2 di 2
    • Follow this guide for in-depth instructions on how to disconnect a coaxial connector.
    • Slide one of the tweezer's tips under the black wire until it's snug against the connector, and pry straight up from the board.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets much like the metal snaps on a jacket.
  16. Motorola Moto G7 Power Daughterboard Replacement: passo 16, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement: passo 16, immagine 2 di 2
    • Slide one of the tweezer's tips under the white wire until it's snug against the connector, and pry straight up from the board.
  17. Motorola Moto G7 Power Daughterboard Replacement, Disconnect the interconnector: passo 17, immagine 1 di 2 Motorola Moto G7 Power Daughterboard Replacement, Disconnect the interconnector: passo 17, immagine 2 di 2
    • Use the flat end of a spudger to pry up on the interconnect cable connector to disconnect it.
  18. Motorola Moto G7 Power Daughterboard Replacement: passo 18, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the 3 mm screw securing the daughterboard to the midframe.
  19. Motorola Moto G7 Power Daughterboard Replacement: passo 19, immagine 1 di 3 Motorola Moto G7 Power Daughterboard Replacement: passo 19, immagine 2 di 3 Motorola Moto G7 Power Daughterboard Replacement: passo 19, immagine 3 di 3
    • Insert the pointed end of a spudger under the right side of the daughterboard to lift it from the midframe.
    • Remove the daughterboard.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G7 Power Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Altre 6 persone hanno completato questa guida.
Clay Kim
Membro da: 02/16/21
9.753 Reputazione
21 Guide realizzate
5 Commenti
IMEI is now 0 and I get "this sim is disabled".....
Jim Hubbard - Replica
So where can I get this daughterboard? I see no link to buy it up there and can't find it anywhere else, either...
rj45 - Replica
Thanks for a well-done guide - very useful! I also replaced the fingerprint sensor after having broken the cable when installing a new battery last year. Nice to have all the capabilities of the phone again!
cbrillow - Replica
I retired my G7 Supra a few years ago. Great extra phone but part of the plastic around the port gave way which led to the charging port getting damaged. I have a use for extra phones and this old girl isn’t a slouch. $11 on Amazon for the part and following this tutorial, I got it done in 30 minutes. Hardest part was the adhesive.
Thanks so much!! It’s now plugged in a turbo charging. I reinforced the plastic around it with two little thin pieces of aluminum and some in weld. Moto definitely had a design flaw there.
I’ll be posting a video to my audience on YouTube (Silly Reviews) and sharing the link to this page.
Silly Reviews - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 48
Tutti i Tempi: 2,400
