Salta al contenuto principale
Motorola Moto E4 Rear Facing Camera Replacement
Nate Tjepkema
Nate Tjepkema e 5 altri collaboratori
Ultimo aggiornamento il May 15, 2023
8 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to remove or replace your Moto E4 rear facing camera.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
Mostra di più…
  1. Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: passo 1, immagine 1 di 2 Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: passo 1, immagine 2 di 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: passo 2, immagine 1 di 2 Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: passo 2, immagine 2 di 2
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Rear Facing Camera Replacement: passo 3, immagine 1 di 2 Motorola Moto E4 Rear Facing Camera Replacement: passo 3, immagine 2 di 2
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Rear Facing Camera Replacement: passo 4, immagine 1 di 3 Motorola Moto E4 Rear Facing Camera Replacement: passo 4, immagine 2 di 3 Motorola Moto E4 Rear Facing Camera Replacement: passo 4, immagine 3 di 3
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
Conclusione
Nate Tjepkema
Membro da: 01/24/19
1.254 Reputazione
7 Guide realizzate
Cal Poly, Team S2-G4, White Winter 2019 Membro di Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 26
Tutti i Tempi: 774
