Salta al contenuto principale
Motorola Edge Loudspeaker Replacement
Cosa ti serve
  1. Motorola Edge Loudspeaker Replacement, Heat the bottom edge: passo 1, immagine 1 di 1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge Loudspeaker Replacement, Separate the bottom adhesive: passo 2, immagine 1 di 3 Motorola Edge Loudspeaker Replacement, Separate the bottom adhesive: passo 2, immagine 2 di 3 Motorola Edge Loudspeaker Replacement, Separate the bottom adhesive: passo 2, immagine 3 di 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge Loudspeaker Replacement, Slice the bottom adhesive: passo 3, immagine 1 di 3 Motorola Edge Loudspeaker Replacement, Slice the bottom adhesive: passo 3, immagine 2 di 3 Motorola Edge Loudspeaker Replacement, Slice the bottom adhesive: passo 3, immagine 3 di 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Motorola Edge Loudspeaker Replacement, Heat the right edge: passo 4, immagine 1 di 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  5. Motorola Edge Loudspeaker Replacement, Separate the corner adhesive: passo 5, immagine 1 di 3 Motorola Edge Loudspeaker Replacement, Separate the corner adhesive: passo 5, immagine 2 di 3 Motorola Edge Loudspeaker Replacement, Separate the corner adhesive: passo 5, immagine 3 di 3
    • Rotate the opening pick around the bottom-right corner of the phone.
  6. Motorola Edge Loudspeaker Replacement, Separate the right adhesive: passo 6, immagine 1 di 3 Motorola Edge Loudspeaker Replacement, Separate the right adhesive: passo 6, immagine 2 di 3 Motorola Edge Loudspeaker Replacement, Separate the right adhesive: passo 6, immagine 3 di 3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  7. Motorola Edge Loudspeaker Replacement, Remove the back cover: passo 7, immagine 1 di 3 Motorola Edge Loudspeaker Replacement, Remove the back cover: passo 7, immagine 2 di 3 Motorola Edge Loudspeaker Replacement, Remove the back cover: passo 7, immagine 3 di 3
    • Remove the back cover, taking care not to damage the components inside the phone.
  8. Motorola Edge Loudspeaker Replacement, Remove the motherboard's screws: passo 8, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  9. Motorola Edge Loudspeaker Replacement, Remove the motherboard cover: passo 9, immagine 1 di 3 Motorola Edge Loudspeaker Replacement, Remove the motherboard cover: passo 9, immagine 2 di 3 Motorola Edge Loudspeaker Replacement, Remove the motherboard cover: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  10. Motorola Edge Loudspeaker Replacement, Disconnect the battery cable's press connector: passo 10, immagine 1 di 2 Motorola Edge Loudspeaker Replacement, Disconnect the battery cable's press connector: passo 10, immagine 2 di 2
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Motorola Edge Loudspeaker Replacement, Remove the daughterboard's t5 screws: passo 11, immagine 1 di 2 Motorola Edge Loudspeaker Replacement, Remove the daughterboard's t5 screws: passo 11, immagine 2 di 2
    • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
  12. Motorola Edge Loudspeaker Replacement, Remove the daughterboard cover: passo 12, immagine 1 di 3 Motorola Edge Loudspeaker Replacement, Remove the daughterboard cover: passo 12, immagine 2 di 3 Motorola Edge Loudspeaker Replacement, Remove the daughterboard cover: passo 12, immagine 3 di 3
    • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
Conclusione
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Jennifer Berg
Membro da: 03/21/22
2.837 Reputazione
24 Guide realizzate
1Commento della guida
I replaced my charging port and needed to move the loudspeaker. When I put my loudspeaker back in my phone I noticed it doesn't work. I believe this also houses the vibration mechanic, and the phone vibrates.
My question is: How does the loudspeaker actually connect to the phone? From what I can see it's just a floating piece with no type of connector from this piece to the phone. I would like to verify if I may have connected it incorrectly before I purchase another loudspeaker.
QuadMind - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 424
