Salta al contenuto principale
Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement
Noah Wargo
Noah Wargo e 2 altri collaboratori
Ultimo aggiornamento il 29 lug 2022
45 minuti
Moderato
Guida Studente in Evidenza
Introduzione
Vai al passo 1
The heating element and temperature sensor are very important in a 3D printer. The former helps to melt the printing material to allow construction, and the latter monitors the temperature of the hot end. When both are faulty, the printer will begin to fail and require replacement.
That is the purpose of this guide: to help to replace both the heating element and the temperature sensor. Additionally, if only one of the two components need replacement, the parts of each step involving the other element can be ignored.
Cosa ti serve
Strumenti
Mostra di più…
  1. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement, Heating Element and Temperature Sensor: passo 1, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement, Heating Element and Temperature Sensor: passo 1, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement, Heating Element and Temperature Sensor: passo 1, immagine 3 di 3
    • Use needle nose pliers to remove the two spring clips on either side of the shroud covering the hotend.
    • Remove the fan with your hand.
  2. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 2, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 2, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 2, immagine 3 di 3
    • Remove the two 18 mm Phillips head screws that secure the shroud.
    • Remove the hot end from the shroud.
  3. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 3, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 3, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 3, immagine 3 di 3
    • Use a small utility knife to cut the insulation covering the heater block.
    • The intent is to access what is under the insulation, not to fully remove it. Fully removing the insulation will likely damage it.
  4. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 4, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 4, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 4, immagine 3 di 3
    • Pull back the insulation until you have access to the grub screw at the bottom of the heater block.
    • Use the hex driver to loosen the grub screw.
    • Remove the heating element from the heater block.
  5. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 5, immagine 1 di 2 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 5, immagine 2 di 2
    • Use the dull side of a utility blade to scrape away excess thermal compound holding the temperature sensor in place.
    • Remove the temperature sensor.
    • The thermal compound is simply the dried paste surrounding the hole where the temperature sensor is located.
  6. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 6, immagine 1 di 2 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 6, immagine 2 di 2
    • Unwind the spiral wrap from the wires leading from the hotend to the printer body.
  7. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 7, immagine 1 di 2 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 7, immagine 2 di 2
    • Lay the printer in its back to access the bottom panel.
    • Remove the six 8 mm Phillips head screws, and carefully remove the bottom panel.
    • Do not disconnect any wires in this step.
  8. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 8, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 8, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 8, immagine 3 di 3
    • Clip the zip ties holding the wire bundle together.
  9. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 9, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 9, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 9, immagine 3 di 3
    • Locate the pair of thick red wires for the heating element and the pair of thin white wires for the temperature sensor.
    • Find where each pair of wires connects to the main board and disconnect them with a pair of needle nose pliers.
    • The large connector for the heating element has a clip that will need to be depressed to disconnect the wires.
  10. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 10, immagine 1 di 2 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 10, immagine 2 di 2
    • Remove the four Phillips head screws holding the vertical section of the printer to the base.
    • These screws are screwed in tightly, be careful not to strip them while removing them.
    • These screws, though also 8 mm, have a slightly smaller diameter than the ones holding on the bottom panel. Keep them separate to avoid mixing them up.
  11. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 11, immagine 1 di 2 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 11, immagine 2 di 2
    • Remove the vertical portion of the printer from the base.
    • Feed the wires for the heating element and the temperature sensor through the hole in the base.
  12. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 12, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 12, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 12, immagine 3 di 3
    • Remove the three Phillips head screws from the bottom of the vertical assembly that hold the front panel in place.
    • Remove the three Phillips head screws from the top of the vertical assembly that hold the front panel.
    • Remove the front panel from the vertical assembly.
  13. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 13, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 13, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 13, immagine 3 di 3
    • Push the wires for the heating element and the temperature sensor through the hole in the top of the vertical assembly.
  14. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 14, immagine 1 di 2 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 14, immagine 2 di 2
    • Cut the remaining zip ties holding the wires together.
  15. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 15, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 15, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 15, immagine 3 di 3
    • Unwind the remaining wire wrap from the bundle of wires.
    • Remove the old heating element and temperature sensor.
  16. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 16, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 16, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 16, immagine 3 di 3
    • Insert the new heating element into the heater block.
    • Tighten the grub screw to secure the heating element.
  17. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 17, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 17, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 17, immagine 3 di 3
    • Insert the new temperature sensor into the heater block.
    • If the sensor doesn't stay in place, it may be necessary to apply a small amount of thermal cement to secure it.
  18. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 18, immagine 1 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 18, immagine 2 di 3 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 18, immagine 3 di 3
    • Use kapton tape to secure the insulation around the heater block.
  19. Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 19, immagine 1 di 2 Monoprice Select Mini V2 3D Printer Heating Element and Temperature Sensor Replacement: passo 19, immagine 2 di 2
    • Feed the wires from the new components through the hole at the top of the vertical assembly.
    • From this point, use steps 15-1 as a guide to reassemble the device, ignoring steps 4 and 5.
    • Remember to replace the zip ties for wire managment.
    • the 4 screws that held the vertical assembly on the base are different than the other screws that held panels on. Tighten them well.
Conclusione
Preparati per le riparazioni future
Acquista tutti
2Commenti sulla guida
Very good. It would be simpler, for those who can contemplate it, to just cut the wires to the heating element and thermistor a couple of inches away from them. and splice the new ones in, paying attention to heat-shrinking the joints. Then you don't have to rewire all the way back to the PCB. You need soldering and heatshrinking facilities for this procedure.
The 'you need' list should also include zip ties.
Esmond Pitt - Replica
Where did you get the new heating element? Would this fix the issue of the printer not printing anything, even after preheating it? That's why mine has been collecting dust for years.
Arthur Lemus - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 48
Tutti i Tempi: 2,635
