Salta al contenuto principale
Model O- Mouse Cable Replacement
Theo SW
Theo SW e 2 altri collaboratori
Ultimo aggiornamento il June 18, 2024
10 - 20 minuti
Facile
Guida Studente in Evidenza
Introduzione
Vai al passo 1
If your mouse is intermittently disconnecting, randomly missing movements and inputs - you might have a broken or damaged mouse cable. The mouse cable carries data from the mouse to your computer. A damaged cable can result in missed mouse movements and inputs. Before starting this guide try a different connector (most likely USB) port on your computer, and inspect the connector for dirt and debris.
This guide shows an easy, step-by-step process on how to replace the mouse cable in a Glorious Model O- mouse.
The mouse should be physically unplugged from your computer prior to beginning your repair.
Cosa ti serve
Strumenti
Mostra di più…
  1. Model O- Mouse Cable Replacement, Mouse Cable: passo 1, immagine 1 di 3 Model O- Mouse Cable Replacement, Mouse Cable: passo 1, immagine 2 di 3 Model O- Mouse Cable Replacement, Mouse Cable: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Turn the mouse over so that the feet are facing you.
    • Remove the bottom two mouse feet using tweezers.
    • If you plan on reusing the mouse feet place them with the adhesive side up.
    It helps if you warm the two feet a little before you pull them off. You can use a hair-dryer or maybe a toaster if you are careful
    Kampi-Akseli - Replica
  2. Model O- Mouse Cable Replacement: passo 2, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
  3. Model O- Mouse Cable Replacement: passo 3, immagine 1 di 3 Model O- Mouse Cable Replacement: passo 3, immagine 2 di 3 Model O- Mouse Cable Replacement: passo 3, immagine 3 di 3
    • Slide the base away from the top housing to avoid the front clips.
    • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
    • Avoid putting strain on the thin LED ribbon cables.
  4. Model O- Mouse Cable Replacement: passo 4, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 4, immagine 2 di 2
    • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
    • Do not pull on the wires.
    • Remove the cable from around the circuit board and from the hole on the front of the mouse.
  5. Model O- Mouse Cable Replacement: passo 5, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 5, immagine 2 di 2
    • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
    • Do not push on the wires.
    are we just taking out the cable and putting the same one in again?
    Isaac Ireland - Replica
  6. Model O- Mouse Cable Replacement: passo 6, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 6, immagine 2 di 2
    • Route the new cable through the slit in the circuit board.
    • Route the new cable behind the pillars.
    • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
    • The cable may not stay in place until the top housing is securely fastened back on.
    Are we putting in the same cable as we took out?
  7. Model O- Mouse Cable Replacement: passo 7, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 7, immagine 2 di 2
    • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
    • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
  8. Model O- Mouse Cable Replacement: passo 8, immagine 1 di 1
    • Screw the two screws back in with a Phillips #0 screwdriver.
    • Do not apply too much force or you risk stripping the screw holes.
  9. Model O- Mouse Cable Replacement: passo 9, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 9, immagine 2 di 2
    • Reapply the mouse feet with the adhesive side sticking to the mouse.
    • There are plastic ridges to help guide the user where to place the mouse feet.
    • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Theo SW
Membro da: 01/22/21
241 Reputazione
1 Guida realizzata
2Commenti sulla guida
Where can I get the replacement cable for it?
Ekke Sten - Replica
does glorius them selfs sell replacment parts ?
aniss-97 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 101
Tutti i Tempi: 12,586
