Introduzione
This guide will show you how to access and remove the right hand speaker of the Surface Pro 4. Although this process is similar to the left speaker replacement, the structure of the device necessitates a slightly different procedure.
If your display is cracked, cover it with strips of packing tape to contain any glass shards and prevent injury.
To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes—but don't overheat it, or you may damage the display.
Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
Insert an opening pick into the gap.
There are tabs on the upper right side and upper left side where it is easier to get a tool under the display.
Slide an opening pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
Separate the top edge last. There are antennas on both sides, so be careful not to damage them. If needed, you can use a bit of isopropyl alcohol to help weaken the adhesive.
The display should now be free of the body of the Surface Pro. Lift it up and away from the rest of the device.
Remove 5mm Torx T4 screw holding the speaker to the frame of the device.
Remove the 3mm Torx T4 screw.
Altre 6 persone hanno completato questa guida.
