Salta al contenuto principale
Microsoft Surface Pro 11 Screen Replacement
Cosa ti serve
  1. Microsoft Surface Pro 11 Screen Replacement, Before you begin: passo 1, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Before you begin: passo 1, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Before you begin: passo 1, immagine 3 di 3
    • Before starting this repair, allow your Surface Pro's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your tablet.
    Chiedi a FixBot
  2. Microsoft Surface Pro 11 Screen Replacement, Open the kickstand: passo 2, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Open the kickstand: passo 2, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Open the kickstand: passo 2, immagine 3 di 3
    • Lay your Surface Pro screen side down and open the kickstand to about a 90‑degree angle.
    Chiedi a FixBot
  3. Microsoft Surface Pro 11 Screen Replacement, Remove the SSD door: passo 3, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD door: passo 3, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD door: passo 3, immagine 3 di 3
    • Use your finger to firmly press down on the SSD door indent until the door pops up.
    • Remove the SSD door.
    Chiedi a FixBot
  4. Microsoft Surface Pro 11 Screen Replacement, Remove the SSD screw: passo 4, immagine 1 di 2 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD screw: passo 4, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the 2.4 mm‑long screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
    Chiedi a FixBot
  5. Microsoft Surface Pro 11 Screen Replacement, Remove the SSD: passo 5, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD: passo 5, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD: passo 5, immagine 3 di 3
    • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
    • Use the flat end of a spudger to gently lift the notched edge of the SSD enough that you can grip the bottom corners with your fingers.
    • Use your fingers or tweezers to pull the SSD straight out of its socket and remove it.
    • During reassembly, getting the SSD fully inserted in its socket can be tricky. If you're having trouble, hold the SSD in place and use the flat end of a spudger to push on the notched edge.
    Chiedi a FixBot
  6. Microsoft Surface Pro 11 Screen Replacement, Adhesive information: passo 6, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Adhesive information: passo 6, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Adhesive information: passo 6, immagine 3 di 3
    • When separating the screen from the frame, don't insert your tool more than the following measurements on the given edges. Otherwise, you may damage your device's internals.
    • 2 mm on the left, right, and bottom edges
    • Don't insert your tool at all near the front facing camera on the top edge
    • 8 mm along the top edge (everywhere besides the front facing camera area)
    Chiedi a FixBot
  7. Microsoft Surface Pro 11 Screen Replacement, Heat the right edge: passo 7, immagine 1 di 1
    • Mild adhesive secures the perimeter of the screen to the frame. Heating the screen will soften the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the right edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer or heat gun. But be careful, as the screen and battery are susceptible to heat damage.
    Chiedi a FixBot
  8. Microsoft Surface Pro 11 Screen Replacement, Separate the right edge adhesive: passo 8, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the right edge adhesive: passo 8, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the right edge adhesive: passo 8, immagine 3 di 3
    • Remember not to insert your pick more than 2 mm on the right edge.
    • Insert the tip of an opening pick under the screen near the bottom of the right speaker cutout.
    • Slide your pick towards the bottom edge and slightly rotate it so the tip goes under the notch in the screen.
    Chiedi a FixBot
  9. Microsoft Surface Pro 11 Screen Replacement: passo 9, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 9, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 9, immagine 3 di 3
    • Slide your pick down the right edge to separate the adhesive securing it.
    • Leave your pick inserted under the bottom right corner to prevent the adhesive from re‑sealing.
    Chiedi a FixBot
  10. Microsoft Surface Pro 11 Screen Replacement, Heat the bottom edge: passo 10, immagine 1 di 1
    Chiedi a FixBot
  11. Microsoft Surface Pro 11 Screen Replacement, Separate the bottom edge adhesive: passo 11, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the bottom edge adhesive: passo 11, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the bottom edge adhesive: passo 11, immagine 3 di 3
    • Remember not to insert your pick more than 2 mm on the bottom edge.
    • Insert a second pick under the bottom right corner of the screen and slide it along the bottom edge to separate the adhesive.
    • Leave your second pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
    Chiedi a FixBot
  12. Microsoft Surface Pro 11 Screen Replacement, Heat the left edge: passo 12, immagine 1 di 1
    Chiedi a FixBot
  13. Microsoft Surface Pro 11 Screen Replacement, Separate the left edge adhesive: passo 13, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the left edge adhesive: passo 13, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the left edge adhesive: passo 13, immagine 3 di 3
    • Insert a third pick under the bottom left corner of the screen and slide it up the left edge, stopping when you get to the bottom of the left speaker cutout.
    • Leave the pick inserted under the screen to prevent the adhesive from re-sealing.
    Chiedi a FixBot
  14. Microsoft Surface Pro 11 Screen Replacement, Heat the top edge: passo 14, immagine 1 di 1
    Chiedi a FixBot
  15. Microsoft Surface Pro 11 Screen Replacement: passo 15, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 15, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 15, immagine 3 di 3
    • Insert a fourth pick under the screen near the top of the left speaker cutout.
    • Slide your pick towards the top edge and slightly rotate it so the tip goes under the notch in the screen.
    Chiedi a FixBot
  16. Microsoft Surface Pro 11 Screen Replacement, Separate the top edge adhesive: passo 16, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the top edge adhesive: passo 16, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the top edge adhesive: passo 16, immagine 3 di 3
    • Remember not to insert your pick more than 8 mm on the top edge.
    • Slide the pick along the top edge and stop before you get to the front facing camera.
    Chiedi a FixBot
  17. Microsoft Surface Pro 11 Screen Replacement: passo 17, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 17, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 17, immagine 3 di 3
    • Be very careful not to touch the front facing camera lens with your tool.
    • Remove the pick enough that it can pass above the front facing camera.
    • Slide the pick along the top edge until it's past the camera.
    Chiedi a FixBot
  18. Microsoft Surface Pro 11 Screen Replacement: passo 18, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 18, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 18, immagine 3 di 3
    • Insert your pick 8 mm under the screen and slide it to the top right corner to separate the remaining adhesive.
    Chiedi a FixBot
  19. Microsoft Surface Pro 11 Screen Replacement, Separate the screen: passo 19, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the screen: passo 19, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Separate the screen: passo 19, immagine 3 di 3
    • Insert the flat edge of two picks under the screen, below the two speaker cutouts.
    • Use the picks to gently pry up the screen, fully separating it from the frame.
    • Don't try to remove the screen yet, as a ribbon cable still connects it to your device.
    • If the screen feels stuck anywhere, use your pick to separate the adhesive in that area. Remember not to insert your pick too far under the screen.
    Chiedi a FixBot
  20. Microsoft Surface Pro 11 Screen Replacement, Flip the screen over: passo 20, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Flip the screen over: passo 20, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Flip the screen over: passo 20, immagine 3 di 3
    • Once the screen is fully separated, flip the top edge over the bottom edge and lay the screen down flat, being careful not to strain the ribbon cable.
    Chiedi a FixBot
  21. Microsoft Surface Pro 11 Screen Replacement, Remove the screen cable shield: passo 21, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Remove the screen cable shield: passo 21, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Remove the screen cable shield: passo 21, immagine 3 di 3
    • Use the tip of a spudger to lift the conductive tape off the copper shield, near the center of your device.
    Chiedi a FixBot
  22. Microsoft Surface Pro 11 Screen Replacement: passo 22, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 22, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement: passo 22, immagine 3 di 3
    • Insert an arm of a pair of angled tweezers in one of the gaps on the edge of the screen cable shield.
    • Use your tweezers to gently pry up and remove the shield.
    • Try to deform the shield as little as possible—you'll reuse it during reassembly.
    Chiedi a FixBot
  23. Microsoft Surface Pro 11 Screen Replacement, Disconnect the screen: passo 23, immagine 1 di 3 Microsoft Surface Pro 11 Screen Replacement, Disconnect the screen: passo 23, immagine 2 di 3 Microsoft Surface Pro 11 Screen Replacement, Disconnect the screen: passo 23, immagine 3 di 3
    • Insert the flat end of a spudger under the notched corner of the screen cable press connector and pry up to disconnect it.
    Chiedi a FixBot
  24. Microsoft Surface Pro 11 Screen Replacement, Remove the screen: passo 24, immagine 1 di 1
    • Grip the screen with both hands and remove it.
    • During reassembly, follow this guide to replace the screen adhesive and install your screen.
    Chiedi a FixBot
Conclusione
Altre 2 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
188.175 Reputazione
1.187 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
25.721 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 17
Ultimi 7 giorni: 81
Ultimi 30 giorni: 351
Tutti i Tempi: 3,485
