Salta al contenuto principale
Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement
Emmaline Sylvester
Emmaline Sylvester e 2 altri collaboratori
Ultimo aggiornamento il January 8, 2024
5 - 15 minuti
Facile
Introduzione
Vai al passo 1
In order to control the speed of your electric skateboard you must have a functioning accelerator. This step-by-step guide will assist you with replacing your accelerator in your Meepo V2 Electric Skateboard Remote in order to guarantee your remote is fully functional and safe to use.
Cosa ti serve
Strumenti
  1. Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement, Accelerator Cable: passo 1, immagine 1 di 2 Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement, Accelerator Cable: passo 1, immagine 2 di 2
    • Peel off the brand sticker from the back of the remote.
  2. Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement: passo 2, immagine 1 di 2 Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver remove the three screws.
  3. Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement: passo 3, immagine 1 di 3 Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement: passo 3, immagine 2 di 3 Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement: passo 3, immagine 3 di 3
    • Lift the backside of the remote off.
    • The marked area is the accelerator cable that needs to be removed.
  4. Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement: passo 4, immagine 1 di 3 Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement: passo 4, immagine 2 di 3 Meepo V2 Electric Skateboard Remote Accelerator Cable Replacement: passo 4, immagine 3 di 3
    • Unplug the connector and remove the accelerator cable.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,050
