Salta al contenuto principale
Medtronic 670G Battery Replacement
Valerie Velez
Valerie Velez e 2 altri collaboratori
Ultimo aggiornamento il March 24, 2025
2 minuti
Facile
Introduzione
Vai al passo 1
This guide demonstrates how to easily replace the battery in a Medtronic 670G Insulin Pump. Replacing the battery of this device is important so that that the device can regulate your insulin and blood sugar as needed. It is crucial for the user to keep track of their health needs. I hope that with this guide will help you on the maintenance of your device.
  1. Medtronic 670G Battery Replacement, Battery: passo 1, immagine 1 di 2 Medtronic 670G Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Detach the clip on the back of the device.
  2. Medtronic 670G Battery Replacement: passo 2, immagine 1 di 3 Medtronic 670G Battery Replacement: passo 2, immagine 2 di 3 Medtronic 670G Battery Replacement: passo 2, immagine 3 di 3
    • Place the small protrusion on the bottom of the clip into the slot on top of the battery housing, and turn it counter clockwise.
  3. Medtronic 670G Battery Replacement: passo 3, immagine 1 di 3 Medtronic 670G Battery Replacement: passo 3, immagine 2 di 3 Medtronic 670G Battery Replacement: passo 3, immagine 3 di 3
    • Remove the battery cap.
    • Dispose of the old battery according to your state guidelines.
  4. Medtronic 670G Battery Replacement: passo 4, immagine 1 di 2 Medtronic 670G Battery Replacement: passo 4, immagine 2 di 2
    • Insert the new battery, making sure the negative end (the flat part of the battery) is facing down.
  5. Medtronic 670G Battery Replacement: passo 5, immagine 1 di 3 Medtronic 670G Battery Replacement: passo 5, immagine 2 di 3 Medtronic 670G Battery Replacement: passo 5, immagine 3 di 3
    • Replace the battery cap tighten until it is aligned.
    • Do not over-tighten the cap as it will make it extremely difficult to unscrew next time.
  6. Medtronic 670G Battery Replacement: passo 6, immagine 1 di 1
    • Turn on the pump and wait until the HOME screen load to make sure the battery is working.
Conclusione
Your Medtronic 670G insulin pump is good-to-go!
Altre 3 persone hanno completato questa guida.
2 Commenti
Hello,
It looks like the Medtronic 670G uses standard AA batteries. You should be able to find AA batteries at most grocery and hardware stores, or online here. We hope that helps!
Connor -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 150
Tutti i Tempi: 2,395
