Salta al contenuto principale
Manual recalibration
  1. Manual recalibration, Manual recalibration: passo 1, immagine 1 di 1
    • Open the Thrustmaster Control panel application and set the angle to 1080°
    • If you are using PlayStation, manually set rotation angle to 1080°
    • Unplug and re-plug T-GT II to USB port.
    • Wait for auto-calibration to finish
  2. Manual recalibration, Steer the wheel all the way to the left: passo 3, immagine 1 di 1
    • Keep turning the wheel until you reach a physical stop
  3. Manual recalibration, Steer the wheel all the way to the right: passo 4, immagine 1 di 1
  4. Manual recalibration, Center your wheel: passo 5, immagine 1 di 1
    • Perfectly center your wheel.
    • Keep in mind that rotation is set to 1080°.
  5. Manual recalibration, Press the indicated buttons: passo 6, immagine 1 di 1
    • Press SHARE + OPTIONS + MODE buttons at the same time.
    • LED will flash if successful.
    • If you are using a different wheel, then a button combination will be different. You can find button combination list here.
Linea Traguardo
Formica Fusca
Membro da: 08/01/24
2.595 Reputazione
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 319
