Salta al contenuto principale
Magic Bullet NutriBullet Base Replacement
Angela Wong
Angela Wong e 4 altri collaboratori
Ultimo aggiornamento il 16 giu 2015
2 minuti
Facile
Introduzione
Vai al passo 1
If you notice any sharp, moving components outside of your NutriBullet base, then use this replacement guide to learn how to remove and replace the base.
Cosa ti serve
Strumenti
  1. Magic Bullet NutriBullet Base Replacement, Base: passo 1, immagine 1 di 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: passo 2, immagine 1 di 2 Magic Bullet NutriBullet Base Replacement: passo 2, immagine 2 di 2
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: passo 3, immagine 1 di 1
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
    ensuite comment défaire le reste
    eliette campeau - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Angela Wong
Membro da: 01/22/15
1.135 Reputazione
3 Guide realizzate
Cal Poly, Team 19-8, Maness Winter 2015 Membro di Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Membri
13 Guide realizzate
3Commenti sulla guida
So far it was easy! Yeah!
Elaine - Replica
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Replica
Where can you buy the base to replace?
Anne-Christine von Wetter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 10,109
