MacBook Pro 13" Retina Display Late 2012 SSD Tray Replacement
Introduzione
Vai al passo 1Use this guide to replace the SSD tray.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
Altre 10 persone hanno completato questa guida.
