Introduzione
Use this guide to replace the Touch ID sensor/power button in an Early 2020 MacBook Air.
Note that Touch ID will not function after replacing the Touch ID sensor. The MacBook’s original Touch ID sensor is uniquely paired to the logic board at the factory—and without Apple’s proprietary calibration process, even a genuine replacement Touch ID sensor from another MacBook Air won’t work.
If you replace the Touch ID sensor, you must install a paired logic board to retain Touch ID functionality.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$16.96
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
Use a T4 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
Remove the audio board connector cover.
Use a T4 Torx driver to remove the three screws securing the audio board:
Two 4.3 mm screws
One 2.4 mm screw
Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
Remove the Touch ID sensor bracket.
Turn the MacBook right-side up and open the display.
Remove the Touch ID sensor.
Altre 4 persone hanno completato questa guida.
3Commenti sulla guida
Hi im going to replace the motherboard/logic board on this model if i take the mb and the id sensor from the same macbook will touch id work
On MacBooks with Touch ID, the logic board and Touch ID sensor must be replaced as a pair.
My laptop :
Serial no. C02CX07GMLVF
A2179 and EMC3302
MacBook Air 13” Retina (A2179, 2020)
Question:
Can I install this safely and return if this doesn't work within 30days?
What is this touch panel pairing? If i plan to use my existing touch panel, does this matter? or does the touch panel come with the logic board?
