Salta al contenuto principale
MacBook Air 11" Mid 2011 Trackpad Replacement
Cosa ti serve
    1. MacBook Air 11" Mid 2011 Trackpad Replacement, Lower Case: passo 1, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Chiedi a FixBot
      Aggiungi Commento
    2. MacBook Air 11" Mid 2011 Trackpad Replacement: passo 2, immagine 1 di 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Chiedi a FixBot
      Aggiungi Commento
    1. MacBook Air 11" Mid 2011 Trackpad Replacement, Battery: passo 3, immagine 1 di 2 MacBook Air 11" Mid 2011 Trackpad Replacement, Battery: passo 3, immagine 2 di 2
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Chiedi a FixBot
      Aggiungi Commento
    2. MacBook Air 11" Mid 2011 Trackpad Replacement: passo 4, immagine 1 di 1
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      Chiedi a FixBot
      Aggiungi Commento
    3. MacBook Air 11" Mid 2011 Trackpad Replacement: passo 5, immagine 1 di 1
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Chiedi a FixBot
      Aggiungi Commento
    1. MacBook Air 11" Mid 2011 Trackpad Replacement, Trackpad: passo 6, immagine 1 di 2 MacBook Air 11" Mid 2011 Trackpad Replacement, Trackpad: passo 6, immagine 2 di 2
      • Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable.
      • Gently slide the ribbon cable out of the ZIF connector.
      • Adjust, but do not remove the T5 Trackpad Sensitivity Screw to change the trackpad's depth sensitivity.
      Chiedi a FixBot
      Aggiungi Commento
    2. MacBook Air 11" Mid 2011 Trackpad Replacement: passo 7, immagine 1 di 3 MacBook Air 11" Mid 2011 Trackpad Replacement: passo 7, immagine 2 di 3 MacBook Air 11" Mid 2011 Trackpad Replacement: passo 7, immagine 3 di 3
      • With one hand, push the keyboard ribbon cable in slightly to access the ZIF connector beneath it.
      • Use a spudger to flip up the retaining flap.
      • Gently slide the cable out of the connector.
      Chiedi a FixBot
      Aggiungi Commento
    3. MacBook Air 11" Mid 2011 Trackpad Replacement: passo 8, immagine 1 di 1
      • Remove the six 1.5 mm Phillips #00 screws holding the trackpad in place.
      • These screws are installed tightly and strip easily. Be careful as you remove them.
      Chiedi a FixBot
      Aggiungi Commento
    4. MacBook Air 11" Mid 2011 Trackpad Replacement: passo 9, immagine 1 di 3 MacBook Air 11" Mid 2011 Trackpad Replacement: passo 9, immagine 2 di 3 MacBook Air 11" Mid 2011 Trackpad Replacement: passo 9, immagine 3 di 3
      • Open the device about 10 degrees.
      • While holding the bottom of the trackpad, press up on the side of the trackpad closest to the logic board to free it from the upper case.
      • Remove the trackpad from the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 29 persone hanno completato questa guida.
Brett Hartt
Membro da: 04/12/10
132.308 Reputazione
144 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
59.990 guide realizzate
7Commenti sulla guida
Bought a T5 screwdriver. Screws on my Macbook Air late 2011 won't turn. I thought one was unscrewing but as it turned out, I was just destroying the screw so it is now stuck forever and I'll never be able to open this thing. Great, I really do have an aluminium pile of trash now.
Andy Barratt - Rispondi Condividi
In the tools list is missing the screwdriver Philips #00
John - Rispondi Condividi
Thanks! Updated.
Andrew Optimus Goldheart - Rispondi Condividi
Please remove this guide. It has errors that cause me to strip one of my track pad screws. (Good otherwise and thanks for writing it.)
There is an almost identical guide Sostituzione trackpad MacBook Air 13" metà 2011
that list the correct screw size #000 for the track pad and also shows the correct battery connector for my 2011 13" MacBook Air.
julie - Rispondi Condividi
The case screws are P5 pentalobe and not torx T5. The battery screws are torx T5.
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 15
Ultimi 30 giorni: 66
Tutti i Tempi: 36,496
