Mac mini Model A1176 Internal Frame Replacement
Introduzione
Vai al passo 1Remove the internal frame to access most of your mini's internals.
Cosa ti serve
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Preparati per le riparazioni future
Acquista tutti
