Introduzione
Learn how to upgrade or replace the memory in your 2018 Mac mini with this RAM replacement guide. The mini can support up to 64 GB of RAM, using any combination of 8 GB, 16 GB, or 32 GB DDR4-2666 SODIMM RAM modules.
Cosa ti serve
Panoramica video
Strumento utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove six TR6 Torx security screws securing the antenna plate, of the following lengths:
Three 4.1 mm shoulder screws
Three 1.8 mm screws
Use a T6 Torx driver to remove the four 7.2 mm screws securing the fan:
Two screws securing the fan to the logic board
Two screws with rubber shoulders securing the fan to the exhaust vent
Grasp the power supply cable and lift to disconnect it from the logic board, wiggling as needed to loosen it up.
Use a T5 Torx driver to remove the four 2.8 mm screws securing the RAM shield.
Altre 399 persone hanno completato questa guida.
