Salta al contenuto principale
MSI GE70 2PE Apache Pro Keyboard Replacement
mazin
mazin e 3 altri collaboratori
Ultimo aggiornamento il May 4, 2019
5 - 10 minuti
Facile
Foto Azione
Passi mancanti
Introduzione Migliore
Cosa ti serve
Strumenti
  1. MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Insert iFixit opening tool as shown in the picture to pry up on the keyboard guard.
    • Remove the keyboard guard.
  2. MSI GE70 2PE Apache Pro Keyboard Replacement: passo 2, immagine 1 di 3 MSI GE70 2PE Apache Pro Keyboard Replacement: passo 2, immagine 2 di 3 MSI GE70 2PE Apache Pro Keyboard Replacement: passo 2, immagine 3 di 3
    • Insert the iFixit tool under the plastic screw cover.
    • Grab the plastic part with your hand and lift it off the casing.
    • Remove the plastic part to reveal the screws holding the keyboard in place.
  3. MSI GE70 2PE Apache Pro Keyboard Replacement: passo 3, immagine 1 di 3 MSI GE70 2PE Apache Pro Keyboard Replacement: passo 3, immagine 2 di 3 MSI GE70 2PE Apache Pro Keyboard Replacement: passo 3, immagine 3 di 3
    • Unscrew the five screws located at the top of the keyboard.
    • Use the opening tool to lift the keyboard from its position
    • Be mindful of the ribbon cables when lifting the keyboard from the palmrest.
Conclusione
Altre 2 persone hanno completato questa guida.
2Commenti sulla guida
What about step 4 detaching the ribbon cable?
russell89000 - Replica
yes missing the part of the 2 ribbon cables, one of them (the lighting) is not reachable like this..
you have to take out the battery, and then remove the back cover to reach the ribbon for the lighting
Kim Van Hoeck - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 61
Tutti i Tempi: 3,901
