Salta al contenuto principale
M3D Micro Motor Replacement
Miguel Pina
Miguel Pina e 3 altri collaboratori
Ultimo aggiornamento il 23 apr 2020
15 minuti
Facile
Introduzione
Vai al passo 1
When printing, your extruder may not work properly, the reason of this may be related to one of the two motors. If you determined that one of the motors could be the ones causing trouble, you will need to replace it. Through this guide we intend to show the step by step process that one must take to safely remove and replace the motor of a M3D Micro.
Cosa ti serve
Strumenti
  1. M3D Micro Motor Replacement, M3D Micro Frame Removal: passo 1, immagine 1 di 1
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Motor Replacement: passo 2, immagine 1 di 3 M3D Micro Motor Replacement: passo 2, immagine 2 di 3 M3D Micro Motor Replacement: passo 2, immagine 3 di 3
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
    I could get it loose on one side. The other is firmly stuck. It does let me flip the head up to the side, but it won’t come loose without significant violence.
    Also, to the the first one loose, I have to pull the Y-rods so hard that they bend. Not plastic deformation, they are not ruined (I think) but the amount of force disturbs me.
    Ragnemalm - Replica
  3. M3D Micro Motor Replacement: passo 3, immagine 1 di 2 M3D Micro Motor Replacement: passo 3, immagine 2 di 2
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
    This doesn’t work at all on my M3D. I had to force in a tool, a kitchen knife, to crack it open in each corner. THEN I can lift it up. (But I still can’t lift it off since I can’t remove the printer head. More force needed there.)
    Reassembly is harder, because you have six rods that must get into separate holes more or less simultaneously, and I guess those small metal rings on the top have a purpose too.
    Ragnemalm - Replica
  4. M3D Micro Motor Replacement, Motor: passo 4, immagine 1 di 1
    • Once the base is opened you should find a circuit board and two motors like the one on the right, select the motor to be replaced.
    You forgot one step: How to remove the base!
    Ragnemalm - Replica
  5. M3D Micro Motor Replacement: passo 5, immagine 1 di 2 M3D Micro Motor Replacement: passo 5, immagine 2 di 2
    • Unplug the connectors for the Orange, Blue, Gray and Black cables. These would be the motor cables.
  6. M3D Micro Motor Replacement: passo 6, immagine 1 di 2 M3D Micro Motor Replacement: passo 6, immagine 2 di 2
    • Once disconnected you will proceed to lift the motor using pliers.
  7. M3D Micro Motor Replacement: passo 7, immagine 1 di 2 M3D Micro Motor Replacement: passo 7, immagine 2 di 2
    • Now, remove the motor.
Conclusione
Preparati per le riparazioni future
Acquista tutti
Miguel Pina
Membro da: 10/17/17
122 Reputazione
1 Guida realizzata
USF Tampa, Team S3-G2, Nance Fall 2017 Membro di USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Membri
10 Guide realizzate
1Commento della guida
Hello, good work and explanation. Is there any possibility to replace MICRO+ X-AXIS MOTOR “gear” please. Thanks
robozeka - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,773
