Salta al contenuto principale
Logitech z-5500 LCD Screen Replacement
Nicolas Cambas
Nicolas Cambas e 2 altri collaboratori
Ultimo aggiornamento il 18 mar 2024
30 minuti
Facile
Guida In Evidenza
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This rather exceptional speaker kit has very few problems, but sometimes the control screen no longer has a backlight or does not work very well.
The goal here is to replace it. Apart from the soldering part, it is a relatively simple operation.
I added references to compatible screens in the part description; I was able to buy mine on aliexpress.com.
  1. Logitech z-5500 LCD Screen Replacement, Disassembling the housing: passo 1, immagine 1 di 2 Logitech z-5500 LCD Screen Replacement, Disassembling the housing: passo 1, immagine 2 di 2
    • Remove the stand by unscrewing the two screws with a #3 Hexagon driver.
    • Remove the 4 screws, one from each corner of the case, with a Phillips #2 screwdriver.
  2. Logitech z-5500 LCD Screen Replacement, Opening the Housing: passo 2, immagine 1 di 2 Logitech z-5500 LCD Screen Replacement, Opening the Housing: passo 2, immagine 2 di 2
    • Remove the volume button on the front of the pod. It may be a little difficult to pull off because it is lightly glued.
    • Separate the two sides by removing the two pieces (black and gray). They are clipped in 3 different places.
    • Be careful not to use too much force (horizontally), as some legs can be quite fragile, like that of the power button.
  3. Logitech z-5500 LCD Screen Replacement, Remove the Display: passo 3, immagine 1 di 3 Logitech z-5500 LCD Screen Replacement, Remove the Display: passo 3, immagine 2 di 3 Logitech z-5500 LCD Screen Replacement, Remove the Display: passo 3, immagine 3 di 3
    • Remove the 4 screws with a Phillips #2 screwdriver.
    • It will be necessary to desolder all the wires in the ribbon cable more or less at the same time. You can also simply cut the end of the ribbon cable and strip the individual wires.
    • Note how the wires are soldered, it's neat.
    • Clean the wires so that they are not too thick. (we can do much better than in the photo!)
  4. Logitech z-5500 LCD Screen Replacement, Solder the New Display: passo 4, immagine 1 di 2 Logitech z-5500 LCD Screen Replacement, Solder the New Display: passo 4, immagine 2 di 2
    • To ensure a good connection between the wires and the circuit board, treat the copper pads with flux first, then tin them with a light coating of solder. Apply the solder sparingly so you don't accidentally fill the hole.
    • Position the wires in the holes, and bend them upwards to make soldering a little easier.
    • My soldering is quite disgusting, but there is no contact between the wires, that's the main thing! Check yours carefully!
  5. Logitech z-5500 LCD Screen Replacement, Reassembly: passo 5, immagine 1 di 1
    • Take this opportunity to clean the dust and the inside of the screen glass! ;)
    • Reassemble the case, plug it in, and enjoy a brand new display! Here we go again for 10 years!
    Can't find the display anywhere in the world ALiexpress & ALiexpress is not shipping to my country India, because our gov banned imports from Aliexpress. I tried finding it on eBay & Amazon but no luck.
    Sush - Replica
Conclusione
To reassemble your device, follow the instructions in reverse order.
Altre 7 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2Commenti sulla guida
Tuto très bien fait !
Très facile à réaliser en sachant qu’il n’y a pas de mauvaise surprise de fixations ou câbles collés. Merci !!!
Ceci étant, on ne trouve l’écran plus qu’ici :
https://fr.aliexpress.com/item/189448119...
https://fr.aliexpress.com/item/100500333...
sebastien_bachene - Replica
Un très bon tuto, bonne réalisation
jpmoureau@sfr.fr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 108
Tutti i Tempi: 6,518
