Salta al contenuto principale
Logitech UE MegaBoom Motherboard Replacement
Oscar Ambriz
Oscar Ambriz e 3 altri collaboratori
Ultimo aggiornamento il January 4, 2018
1 - 2 ore
Moderato
Introduzione
Vai al passo 1
This guide will assist you with the removal and replacement of the Logitech UE Megaboom motherboard.
Cosa ti serve
Strumenti
Mostra di più…
  1. Logitech UE MegaBoom Motherboard Replacement, Outer Mesh: passo 1, immagine 1 di 3 Logitech UE MegaBoom Motherboard Replacement, Outer Mesh: passo 1, immagine 2 di 3 Logitech UE MegaBoom Motherboard Replacement, Outer Mesh: passo 1, immagine 3 di 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Motherboard Replacement: passo 2, immagine 1 di 3 Logitech UE MegaBoom Motherboard Replacement: passo 2, immagine 2 di 3 Logitech UE MegaBoom Motherboard Replacement: passo 2, immagine 3 di 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Motherboard Replacement: passo 3, immagine 1 di 2 Logitech UE MegaBoom Motherboard Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Motherboard Replacement, Battery: passo 4, immagine 1 di 1
    • Pull on white strip to remove battery.
    • Remove inner plastic gasket on circuit board.
    • Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
    • Gently pry circuit board up out of recess.
  5. Logitech UE MegaBoom Motherboard Replacement, Speaker: passo 7, immagine 1 di 2 Logitech UE MegaBoom Motherboard Replacement, Speaker: passo 7, immagine 2 di 2
    • Insert a opening tool between the grating and the body of the speaker
    • Pry up allowing the tabs to pop out of place.
    • There will be an audible sound when the tabs have begun to pop out of place.
    • Apply the same procedure to the grating covering the second speaker.
  6. Logitech UE MegaBoom Motherboard Replacement: passo 8, immagine 1 di 2 Logitech UE MegaBoom Motherboard Replacement: passo 8, immagine 2 di 2
    • Use a opening tool to push the thin metal rod located on the side of the speaker out.
    • Using needle nose pliers grasp the rod and pull the rod out of the speaker until fully removed.
    • Remove the remaining three rods.
    • One is located on the same side and two are located on the other speaker.
  7. Logitech UE MegaBoom Motherboard Replacement: passo 9, immagine 1 di 3 Logitech UE MegaBoom Motherboard Replacement: passo 9, immagine 2 di 3 Logitech UE MegaBoom Motherboard Replacement: passo 9, immagine 3 di 3
    • Insert a opening tool between the speaker and the base
    • Pry up allowing the speaker tabs to pop out of place
    • Find and disconnect the wire from the motherboard by pulling in an upward motion.
    • Apply the same procedure to the second speaker.
  8. Logitech UE MegaBoom Motherboard Replacement, Motherboard: passo 10, immagine 1 di 1
    • Grasp the mother board by the wider edge and pull towards yourself.
    • This should not require much force.
Conclusione
Altre 2 persone hanno completato questa guida.
Oscar Ambriz
Membro da: 09/27/17
962 Reputazione
6 Guide realizzate
Cal Poly, Team S9-G2, Banghart Fall 2017 Membro di Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 24
Tutti i Tempi: 5,090
