Logitech Harmony Touch Screen Replacement
Introduzione
Vai al passo 1If you find that your remote control touchscreen has stopped working correctly or has been damaged, you may need to replace it in order to continue using the device. This guide will help you to access the touchscreen of the Logitech Harmony remote universal.
Cosa ti serve
Open the latch that accesses the charging port.
Remove the black sticker and remove the screw with the indicated screw driver.
Take the plastic opening tool and run it down the side of the remote to pop the case open.
Detach the white clamp to partially disconnect the case from the motherboard.
Carefully remove the motherboard from the top piece of the case.
Don't pull too hard on the motherboard...like this person said, the motherboard is connected to the screen which is also connected to the top of the remote (piece with buttons) by a very thin copper cable with what looks like a chip. You rip that and you're out of luck. Ask me how I know ;)
Altre 2 persone hanno completato questa guida.
2Commenti sulla guida
do you have the lcd screen P/N???
