Salta al contenuto principale
Logitech Harmony Smart Control Remote Buttons Replacement
Josh Hendricks
Josh Hendricks e 4 altri collaboratori
Ultimo aggiornamento il 23 mag 2016
8 - 15 minuti
Facile
Introduzione Migliore
Cosa ti serve
Strumenti
  1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: passo 1, immagine 1 di 2 Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: passo 1, immagine 2 di 2
    • With both thumbs, slide the grooved cover off the end of the remote.
    • Remove the battery once cover is removed.
  2. Logitech Harmony Smart Control Remote Buttons Replacement: passo 2, immagine 1 di 2 Logitech Harmony Smart Control Remote Buttons Replacement: passo 2, immagine 2 di 2
    • With the PH00 bit, remove both of the 4mm Phillip screws on the remote.
  3. Logitech Harmony Smart Control Remote Buttons Replacement: passo 3, immagine 1 di 2 Logitech Harmony Smart Control Remote Buttons Replacement: passo 3, immagine 2 di 2
    • Using a metal spudger, pry the remote. Maneuver around to separate both sides.
  4. Logitech Harmony Smart Control Remote Buttons Replacement: passo 4, immagine 1 di 3 Logitech Harmony Smart Control Remote Buttons Replacement: passo 4, immagine 2 di 3 Logitech Harmony Smart Control Remote Buttons Replacement: passo 4, immagine 3 di 3
    • Manualy separate the two pieces of plastic.
    • Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
    • When the circuit board is pried, slide the circuit board out of the housing.
  5. Logitech Harmony Smart Control Remote Buttons Replacement: passo 5, immagine 1 di 1
    • From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
    too bad the buttons aren’t serviceable. atleast on the version i have.. you can’t clean or repair them. the rubber buttons aren’t the conductive contact. that part is under metal domes mounted on the PCB under a sealed layer of clear plastic. those metal domes don’t appear to be repairable.
    Kevin - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
IUPUI, Team 3-2, Harley Fall 2015 Membro di IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membri
5 Guide realizzate
9Commenti sulla guida
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
fhaist - Replica
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Benoit Lagarde -
Where do you purchase button replacements?
Steve Lutes - Replica
Flavio Campos - Replica
Excellent! I wasn’t sure if it was possible to crack it open or not. Thanks, I was able to clean it up.
John Wall - Replica
I run an electronic repair shop and unlike other cleanable carbon surface remote units, the buttons on these remotes are “sealed” contacts that sit under a rubber press pad, yesterday, my wife tried using alcohol to “clean” the top of the remote. the problem w/ that is the oils on the unit are dissolved and slowly migrate to the “sealed” button pad, which isn’t very well sealed at all. there’s no way to clean those button pads as they cannot be disassembled, So, its now a brick. Also, over time, the buttons just stop working. Again, no fix for this since the buttons themselves are “sealed”. I have 4 of these and I throw them away as they fail since there is no cleaning or replacement of the button pads available.
Jeff Stevenson - Replica
Next time one goes dead send it to me! All I need is the rubber button pad to resurrect my remote :)
MedDev Dude -
Thanks for this, but unfortunately I didn't see anything obviously wrong on the inside. I cleaned up the contacts with iso alcohol, but it still doesn't work.
Brian Y - Replica
Chris Barnes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,022
