Salta al contenuto principale
Logitech Harmony Companion Remote Battery Replacement
Cassidy Wardlow
Cassidy Wardlow e 2 altri collaboratori
Ultimo aggiornamento il April 8, 2024
2 minuti
Facile
Introduzione
Vai al passo 1
If you are still having problems with your Companion remote after changing the command settings, it may be time to change the remote battery. This guide will help you access and replace your Companion remote battery. There are no tools required for this guide, all you need to do is remove the battery cover and lift the battery.
Cosa ti serve
Ricambi
  1. Logitech Harmony Companion Remote Battery Replacement, Remote Battery: passo 1, immagine 1 di 1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Remote Battery Replacement: passo 2, immagine 1 di 1
    • Push the battery cover upward.
    MY Logitech Harmony smart control does NOT have a battery door. There is absolutely no way to get to any battery HELP
    ussscamp - Replica
  3. Logitech Harmony Companion Remote Battery Replacement: passo 3, immagine 1 di 3 Logitech Harmony Companion Remote Battery Replacement: passo 3, immagine 2 di 3 Logitech Harmony Companion Remote Battery Replacement: passo 3, immagine 3 di 3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Nance Fall 2017 Membro di USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Membri
4 Guide realizzate
3Commenti sulla guida
Article fails without mentioning the type of battery the remote uses.
Dave Rombeck - Replica
The battery type is CR2032 3v Lithium coin/button cell
Harmeet Tatla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 111
Tutti i Tempi: 25,273
