Salta al contenuto principale
Logitech Harmony Companion Harmony Hub Motherboard Replacement
Cassidy Wardlow
Cassidy Wardlow e un altro collaboratore
Ultimo aggiornamento il December 13, 2017
Nessuna stima
Moderato
Introduzione
Vai al passo 1
If you are having trouble with your Harmony Hub, the motherboard may need to be replaced. For this guide, all you need is a Phillips #0 screwdriver. There are many screws, so be sure to set them on a mat so none of them get lost.
Cosa ti serve
Strumenti
  1. Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: passo 1, immagine 1 di 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: passo 1, immagine 2 di 2
    • Remove the non-slip rubber pads on the bottom of the Harmony Hub.
  2. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 2, immagine 1 di 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 2, immagine 2 di 2
    • Unscrew the four 6.0 mm Phillips #0 screws.
  3. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 3, immagine 1 di 1
    • Insert the metal opening tool in the slit by the sensor.
    • Carefully separate the Harmony Hub cover from the base.
    • The metal opening tool could damage the device, so use with care.
  4. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 4, immagine 1 di 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 4, immagine 2 di 2
    • Unscrew the 2.0 mm Phillips #0 at the bottom right of the motherboard.
    • Unscrew the 4.0 mm Phillips #0 at the top left of the motherboard.
  5. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, immagine 1 di 3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, immagine 2 di 3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, immagine 3 di 3
    • Face the Harmony Hub base so the sensor is facing out.
    • Insert the plastic opening tool behind the motherboard on the gold section, which is to the right of the sensor.
    • Lift until you hear a click.
Conclusione
USF Tampa, Team S1-G3, Nance Fall 2017 Membro di USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 538
