Salta al contenuto principale
Logitech Harmony Companion Button Pad Replacement
Cassidy Wardlow
Cassidy Wardlow e 2 altri collaboratori
Ultimo aggiornamento il December 13, 2017
2 minuti
Facile
Introduzione
Vai al passo 1
The buttons on your Companion remote may stop working or become damaged. This guide will show you how to replace the button pad in your remote. All you'll need for this guide is a plastic opening tool and Phillips #0 screwdriver.
Cosa ti serve
Strumenti
Mostra di più…
  1. Logitech Harmony Companion Button Pad Replacement, Remote Battery: passo 1, immagine 1 di 1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Button Pad Replacement: passo 2, immagine 1 di 1
    • Push the battery cover upward.
    MY Logitech Harmony smart control does NOT have a battery door. There is absolutely no way to get to any battery HELP
    ussscamp - Replica
  3. Logitech Harmony Companion Button Pad Replacement: passo 3, immagine 1 di 3 Logitech Harmony Companion Button Pad Replacement: passo 3, immagine 2 di 3 Logitech Harmony Companion Button Pad Replacement: passo 3, immagine 3 di 3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: passo 4, immagine 1 di 2 Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: passo 4, immagine 2 di 2
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Button Pad Replacement: passo 5, immagine 1 di 2 Logitech Harmony Companion Button Pad Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Button Pad Replacement: passo 6, immagine 1 di 2 Logitech Harmony Companion Button Pad Replacement: passo 6, immagine 2 di 2
    • Use the plastic opening tool to remove the motherboard.
    Pay careful attention to how the battery holders (the wires at the top) are positioned before removing, especially the springs which are designed to push the battery out when lifted, but if not carefully reinstalled will not allow the battery click into place.
    Tom Scott - Replica
  7. Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, immagine 1 di 3 Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, immagine 2 di 3 Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, immagine 3 di 3
    • Lift the button pad up to remove it from the remote.
    Where can I buy the new buttons?
    R Moller - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Nance Fall 2017 Membro di USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Membri
4 Guide realizzate
4Commenti sulla guida
Ou pouvons nous commander «  Logitech Harmony Companion Button Pad Replacement »
Roger Tardif - Replica
Where can I purchase the button pad?
elijah - Replica
Also looking to find where to purchase. I called Logitech and they were clueless. My 4 year old was better equipped to respond.
Joshua Fuller - Replica
Thanks for posting these helpful steps. My harmony Companion was frustrating us because we had to press buttons really hard.
Cy Beaux - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,269
