Salta al contenuto principale
Logitech G910 Volume Control Wheel Replacement
Sulamita Martynenko
Sulamita Martynenko e 8 altri collaboratori
Ultimo aggiornamento il 20 feb 2024
5 - 7 minuti
Facile
Attrezzi Non Corretti
Passi mancanti
Introduzione Migliore
Dettagli Mancanti
Introduzione
Vai al passo 1
Use this guide to replace the volume control wheel in your device. You won't be needing any special skills for this guide.
Cosa ti serve
Strumenti
  1. Logitech G910 Volume Control Wheel Replacement, Volume control wheel: passo 1, immagine 1 di 1
    • Push the metal spudger underneath the two layers of the keyboard. Using your hand to add pressure, push it downward revolving it to open.
    You skipped all the steps of unscrewing….
    Richard Baranski - Replica
  2. Logitech G910 Volume Control Wheel Replacement: passo 2, immagine 1 di 2 Logitech G910 Volume Control Wheel Replacement: passo 2, immagine 2 di 2
    • Using your fingers, gently remove the volume control wheel from the device.
    That is the volume control
    Joseph Wellman - Replica
    • There are two versions of the Logitech 910—an older one and a newer one.
    • The old version has the 5mm decoder soldered on a small PCB which is connected to the main board by a 3-wire ribbon. You have to de-solder the wire connected to the small PCB side to complete the remaining work.
    • Refer to this video for more information.
    • On the new version, the 5mm decoder is directly connected to the roller. It is recommended to use a small plastic spudger to unlatch the right side of roller shaft first, then carefully take out the encoder and roller together. Use a spudger if needed. There is a tinny shaft connects to the encoder tends to break.
    • After replacing the encoder, either solder it back to the small PCB for the old version, or three wires to the three pins of encoder. It doesn't matter if Red is on the left or right. However, make sure the encoder hexagon hole is facing the roller.
    • For the old version, make sure the encoder is soldered in the same way when you took the old one out. The worst case is the volume control function will be reversed.
    • For the new version, the 3-pin JST ZH 1.5mm connector has three wire colors, Red, Black, and Blue. The Blue wire is for the GND, and make sure it's connected to the encoder middle pin. Solder the other two wires to the remaining two pins.
    • Insert the roller tiny hexagon shaft to the encoder. For the OEM parts, the plastics side of encoder is facing the roller.
    • Connect the keyboard USB cable to a running PC. Test the function of the volume control before putting the roller back to the slot. If the volume control is reversed, no need to rewire the encoder pin connections, just flip the encoder, and insert the roller shaft from the other side.
    • If the volume control function works properly, then carefully put the assembly back to the roller slot, and similar to de-assemble process. Click in the right side first, and then left side. Make sure the force is applied to the roller bulk shaft not to roller itself when seating the roller.
Conclusione
Preparati per le riparazioni future
Acquista tutti
2Commenti sulla guida
Where can I get the replacement part to fix it? I found this german tutorial but it involves completely dismantling the volume control unit and I would rather avoid having to do that. Here’s that tutorial I mentioned earlier. https://www.youtube.com/watch?v=9MDrfD9I...
Tom Sid - Replica
Too many steps skipped.
James Powers - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 60
Tutti i Tempi: 7,185
