Salta al contenuto principale
Lew's Mach Crush Speed Spool Disassembly
Rebecca Welch
Rebecca Welch e 4 altri collaboratori
Ultimo aggiornamento il June 27, 2024
20 - 50 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Guide for disassembly to allow for repair, greasing, and cleaning of parts of baitcaster.
Cosa ti serve
Strumenti
Documento in evidenza
    • Refer to the featured document for specific part names and exploded view. Determine whether you have the right-handed or left-handed reel.
  1. Lew's Mach Crush Speed Spool Disassembly, Remove Left-Side Cover: passo 2, immagine 1 di 2 Lew's Mach Crush Speed Spool Disassembly, Remove Left-Side Cover: passo 2, immagine 2 di 2
    • Slide switch to 'open' on left side of reel to remove left cover.
  2. Lew's Mach Crush Speed Spool Disassembly, Spool Assembly: passo 3, immagine 1 di 1
    • Remove the palm-side cover, then spool assembly from center frame of reel.
  3. Lew's Mach Crush Speed Spool Disassembly, Lube-Port Screw: passo 4, immagine 1 di 1
    • Remove lube-port screw using small Phillips screwdriver.
  4. Lew's Mach Crush Speed Spool Disassembly, Lube-Port Cover: passo 5, immagine 1 di 1
    • Remove cover off of lube-port.
  5. Lew's Mach Crush Speed Spool Disassembly, Handle Screw: passo 6, immagine 1 di 1
    • Remove screw and handle nut from reel.
  6. Lew's Mach Crush Speed Spool Disassembly, Removal of Handle: passo 7, immagine 1 di 1
    • Remove handle and handle nut retainer.
  7. Lew's Mach Crush Speed Spool Disassembly, Drag-Dial: passo 8, immagine 1 di 1
    • Unscrew star-drag until it is loose, remove it and the handle washer from the shaft.
    • Note: You may have to hold the reels gears in place in order to unscrew the drag, as it will try to spin the gears.
  8. Lew's Mach Crush Speed Spool Disassembly, Exterior Right-Cover Screws: passo 9, immagine 1 di 1
    • Remove three spool cover screws from reel.
  9. Lew's Mach Crush Speed Spool Disassembly, Cap: passo 10, immagine 1 di 1
    • Remove cast control cap.
  10. Lew's Mach Crush Speed Spool Disassembly, Removal of Right-Cover: passo 11, immagine 1 di 1
    • Pry 2 drag spring washers, and 1 click holder washer off to finish removing side cover.
  11. Lew's Mach Crush Speed Spool Disassembly, Removal of Pinion: passo 12, immagine 1 di 1
    • Remove the pinion yoke and 2 pinion yoke springs
  12. Lew's Mach Crush Speed Spool Disassembly, Removal of Main Gear: passo 13, immagine 1 di 1
    • Remove drive gear and accompanying drag and ratchet washers.
  13. Lew's Mach Crush Speed Spool Disassembly, Apply Oil: passo 14, immagine 1 di 1
    • Apply oil to main gear if desired.
  14. Lew's Mach Crush Speed Spool Disassembly, Make any necessary changes: passo 15, immagine 1 di 1
    • At this point, you have disassembled the reel enough to where you can clean parts, remove dust and debris , or replace individual parts
Conclusione
Altre 2 persone hanno completato questa guida.
Documenti Allegati
Rebecca Welch
Membro da: 03/31/22
250 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 603
