Lenovo Yoga 720-15IKB Wireless Adapter Replacement
Introduzione
Vai al passo 1If your Lenovo Yoga 720-15IKB (88YG7000828) is not recognizing any wireless signals or having trouble connecting to Wi-Fi, use this guide to replace the wireless adapter. For more information on these symptoms, refer to the troubleshooting guide.
To complete this repair you’ll need a Torx T5 and a Phillips #0 screwdriver.
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
Lift the foam covering the connecting wires and screw, and use the Phillips #0 screwdriver to remove the 2mm screw.
