Salta al contenuto principale
Lenovo Yoga 2 11" Battery Replacement
Abbey Hickmann
Abbey Hickmann e 7 altri collaboratori
Ultimo aggiornamento il May 7, 2024
10 minuti
Facile
Introduzione
Vai al passo 1
As time passes, a battery loses its capability to hold a single charge. This guide will aide users in removing the back panel to reach and replace the faulty battery. Remember to turn the laptop off prior to the repair.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: passo 2, immagine 1 di 1
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: passo 4, immagine 1 di 1
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: passo 5, immagine 1 di 2 Lenovo Yoga 2 11" Battery Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: passo 6, immagine 1 di 1
    • Once all of the wires are detached, carefully remove the battery and replace.
Conclusione
Altre 12 persone hanno completato questa guida.
Cal Poly, Team 4-3, Maness Fall 2015 Membro di Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Membri
5 Guide realizzate
4Commenti sulla guida
how do I remove unathorized battery error?
Manuel Durugas - Replica
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Replica
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Replica
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 56
Tutti i Tempi: 26,951
