Salta al contenuto principale
Lenovo Y50-70 Touch Fan Replacement
Vivian
Vivian e 9 altri collaboratori
Ultimo aggiornamento il January 9, 2025
15 minuti
Facile
Fallo a Fettine
Introduzione
Vai al passo 1
This guide will instruct you how to remove a broken Lenovo Y50-70 Touch Fan from your laptop. A touch fan regulates the laptop’s temperature to keep it from overheating, and when it malfunctions it can damage the laptop or make it perform poorly. A fan can get worn out due to frequent use, causing it to malfunction. Dust or debris can also damage the fan. This replacement process requires a careful hand to avoid harming any internal wiring when removing the base of the laptop and the fan itself. To replace the fan, follow these steps in reverse.
Cosa ti serve
Strumenti
  1. Lenovo Y50-70 Touch Fan Replacement, Back: passo 1, immagine 1 di 2 Lenovo Y50-70 Touch Fan Replacement, Back: passo 1, immagine 2 di 2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: passo 2, immagine 1 di 2 Lenovo Y50-70 Touch Fan Replacement: passo 2, immagine 2 di 2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: passo 3, immagine 1 di 2 Lenovo Y50-70 Touch Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: passo 4, immagine 1 di 3 Lenovo Y50-70 Touch Fan Replacement: passo 4, immagine 2 di 3 Lenovo Y50-70 Touch Fan Replacement: passo 4, immagine 3 di 3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: passo 5, immagine 1 di 3 Lenovo Y50-70 Touch Fan Replacement: passo 5, immagine 2 di 3 Lenovo Y50-70 Touch Fan Replacement: passo 5, immagine 3 di 3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: passo 6, immagine 1 di 3 Lenovo Y50-70 Touch Fan Replacement: passo 6, immagine 2 di 3 Lenovo Y50-70 Touch Fan Replacement: passo 6, immagine 3 di 3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: passo 7, immagine 1 di 2 Lenovo Y50-70 Touch Fan Replacement: passo 7, immagine 2 di 2
    • Lift the fan off of the laptop.
Conclusione
Altre 8 persone hanno completato questa guida.
Vivian
Membro da: 01/21/15
351 Reputazione
1 Guida realizzata
Cal Poly, Team 18-1, Maness Winter 2015 Membro di Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 20
Tutti i Tempi: 9,417
