Lenovo V15-ADA Hard Disk Drive (HDD) Replacement
Introduzione
Vai al passo 1This guide will show how to access, disconnect, and remove the hard-disk drive from your Lenovo V15-ADA device.
Cosa ti serve
Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
M2.5 × 7 mm, Phillips-head (6) (RED circles)
M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
Attach a PH0 head onto the screwdriver and remove screw. (M2 × 6 mm, Phillips-head, nylok-coated)
