Salta al contenuto principale
Lenovo Thinkpad X201 Trackpad Replacement
Peter Gachuki
Peter Gachuki e 7 altri collaboratori
Ultimo aggiornamento il June 14, 2023
10 - 15 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
If the Trackpad on your Lenovo Thinkpad X201 laptop is unresponsive, broken, or faulty, follow this guide to replace it.
A trackpad, or touchpad, is a pointing device similar to a computer mouse, featuring a tactile sensor. A tactile sensor is a specialized surface that can translate the motion and position of a user's fingers to a relative position on the operating system that is then displayed on the screen.
Happy Fixing!
Warning:
Before beginning the trackpad repair, make sure to power off your laptop and disconnect it from outside power sources, such as a wall socket.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
  1. Lenovo Thinkpad X201 Trackpad Replacement, Trackpad: passo 1, immagine 1 di 1
    • Flip the laptop so that the rear side is visible.
    • Slide the switch located near the top of the laptop.
  2. Lenovo Thinkpad X201 Trackpad Replacement: passo 2, immagine 1 di 2 Lenovo Thinkpad X201 Trackpad Replacement: passo 2, immagine 2 di 2
    • Slide out the battery near the top of the laptop.
  3. Lenovo Thinkpad X201 Trackpad Replacement: passo 3, immagine 1 di 1
    • Remove all screws found on the rear side of the laptop using a Phillips #00 screwdriver.
  4. Lenovo Thinkpad X201 Trackpad Replacement: passo 4, immagine 1 di 2 Lenovo Thinkpad X201 Trackpad Replacement: passo 4, immagine 2 di 2
    • Push the silver bar on the side of the laptop downwards.
    • The trackpad will pop up.
  5. Lenovo Thinkpad X201 Trackpad Replacement: passo 5, immagine 1 di 1
    • If step 4 does not work, gently push the bar down while using your other hand to pull the trackpad up.
  6. Lenovo Thinkpad X201 Trackpad Replacement: passo 6, immagine 1 di 3 Lenovo Thinkpad X201 Trackpad Replacement: passo 6, immagine 2 di 3 Lenovo Thinkpad X201 Trackpad Replacement: passo 6, immagine 3 di 3
    • Remove the trackpad from the laptop.
Conclusione
Peter Gachuki
Membro da: 03/26/18
666 Reputazione
4 Guide realizzate
Un commento
nice tutorial. thanks a lot
PiterYT - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,338
