Salta al contenuto principale
Lenovo ThinkPad E570 CMOS Battery Replacement
Geoffrey Gwin
Geoffrey Gwin e 4 altri collaboratori
Ultimo aggiornamento il July 1, 2024
3 - 5 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to replace the CMOS battery in your Lenovo ThinkPad E570 laptop. Your laptop may need a new CMOS battery if you are experiencing the following symptoms:
  • The laptop has difficulty booting up
  • There is a constant beeping noise from the motherboard
  • The date and time have reset each time you restart the device
  • Peripherals aren’t responsive or they don’t respond correctly
  • Hardware drivers have disappeared
  • You can’t connect to the internet
Power down your laptop and disconnect from any external power sources before beginning this guide.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Lenovo ThinkPad E570 CMOS Battery Replacement, CMOS Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad E570 CMOS Battery Replacement, CMOS Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad E570 CMOS Battery Replacement, CMOS Battery: passo 1, immagine 3 di 3
    • Turn the laptop over so that the bottom is facing upwards, with the battery facing away from you.
    • Loosen two captive 5 mm screws on the back panel of the laptop using a Phillips #0 screwdriver.
    • Slide the panel towards you, then gently lift up to remove.
  2. Lenovo ThinkPad E570 CMOS Battery Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad E570 CMOS Battery Replacement: passo 2, immagine 2 di 2
    • Insert the flat end of the halberd spudger underneath the battery to free the it from the adhesive.
    • Unplug the connecting CMOS wire from the motherboard.
    • When reassembling, apply gentle pressure to the new CMOS battery with the adhesive pad facing down.
Conclusione
IUPUI, Team 1-2, Harley Summer 2023 Membro di IUPUI, Team 1-2, Harley Summer 2023
IUPUI-HARLEY-SU23S1G2
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 47
Tutti i Tempi: 390
