Salta al contenuto principale
Lenovo Legion Y530-15ICH Speaker  Replacement
Kimberly Caroline Winkler
Kimberly Caroline Winkler e 4 altri collaboratori
Ultimo aggiornamento il March 18, 2024
25 - 30 minuti
Facile
Foto Azione
Necessarie Immagini Migliori
Necessarie Più Immagini
Introduzione Migliore
Introduzione
Vai al passo 1
This guide illustrates how to remove speakers from the Lenovo Legion Y5530-15ICH. Users may want to replace damaged speakers or upgrade the speakers.
  1. Lenovo Legion Y530-15ICH Speaker  Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Speaker  Replacement: passo 2, immagine 1 di 2 Lenovo Legion Y530-15ICH Speaker  Replacement: passo 2, immagine 2 di 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Speaker  Replacement, Battery: passo 3, immagine 1 di 1
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Speaker  Replacement: passo 4, immagine 1 di 2 Lenovo Legion Y530-15ICH Speaker  Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
  5. Lenovo Legion Y530-15ICH Speaker  Replacement, Speaker: passo 5, immagine 1 di 1
    • Remove the five screws using the Phillips #0 screwdriver.
  6. Lenovo Legion Y530-15ICH Speaker  Replacement: passo 6, immagine 1 di 1
    • Gently peel up the copper adhesive.
  7. Lenovo Legion Y530-15ICH Speaker  Replacement: passo 7, immagine 1 di 1
    • Remove the speakers from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,678
